Electric Fiat 124
ElectricSpider
Your car is a: 1980 Fiat 124 2000 Pininfarina
Contact:
Re: Electric Fiat 124
Post by ElectricSpider »
1973 Fiat 294 "Oriental Yellow". We are using a period correct paint code to match the retro design mods we are incorporating into the build.
Zoofly wrote:The work you guys are doing is incredible. I have an orange 1978 resto-mod that I will be repainting soon. Can you reveal the color code you used for your orange?
Zoofly
Post by Zoofly »
It's a great color. It looks modern like the "Mustang Fury" orange but even better, is it's true to the period you're going for.
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
ElectricSpider
Contact:
Custom three hole cluster is being made is dark wood. Will be a 2 piece dash similar to the Red electric Fiat build. ......
ElectricSpider
Contact:
Electric Fiat 124 Motor Mounts
Motor mount placement. Picked up a couple mounts from Autoricambi. The upper brackets pick up the ears of the motor adapter plate. Places motor weight forward nicely.
Rotoariesarecool
Re: Electric Fiat 124 Motor Mounts
Post by Rotoariesarecool »
hey just had a quick question, on your completed show car
do you remember are those the gloss metal finish: http://www.vickauto.com/newstore/index. ... 13948de4a0
or the flat finish: http://www.vickauto.com/newstore/index. ... ts_id=4345
corsa wheels? thanks.
ElectricSpider
Contact:
Electric Fiat 124
And Away we go with all new and repaired underparts in preparation for the EV system.....
Suspension all off. New trans ready (Thanks Matt from Midwest Bayless)
Rear End needs a little love. Rust be gone time:
See through parts:)
Driveline off to balance and get new carrier bearings etc
ElectricSpider
Contact:
Rebuilt Driveline and balanced.
Parts and hardware:)
Rebuilt hubs..... note the milled edges to fit the new wheels......
These were toast..... :( But a little fab work, rebuild and powder coat.... it will be up tp par.
ElectricSpider
Contact:
Electric Fiat 124 Motor Installation
Installation starting.... This week will have P&P EV System installed. Pre-bench tested and wires ready for installation.
Some buttoning up of the Tesla S battery Module
Mated to the new 124 Trans for easy drop in.
Custom motor mount off the adapter plate face.
Using a stock Fiat motor mount which will connect up to the OEM mount positions.
Thanks to Mark Allison for rebuilding the rear end and turning it around fast! All new everything under the car.
joelittel
Post by joelittel »
Will you be offering plug and play kits for the 124?
ElectricSpider
Contact:
Yes! It will be our 1st system ready to go. We are essentially open to orders for the 124 system. One has been ordered for a neat 124 build in Seattle that should be a fun watch @project_eabarth being performed @theshopseattle
We will be documenting and posting the installation work this and next week on instagram @electricgte and also @electronmonkey. Some youtube and posts here will be made as well.
There will be 2 battery/motor options: 25/35 kWhr Tesla based modules mated with the 120/144v Hyper 9 motors respectively. The 144v motor has a bit longer torque run out on RPM’s. Base info: 125HP/175ft-lbs.
We are solidifying the final components list and labor to pre-build/run the systems. Complete assembly and bench testing occurs prior to shipping. 90 day order time frame currently. Looks like it will be a little more than the price of buying @8 decent Fiat 124’s:) $35-40k. 25/35 and the any shop/folks w some basic fabrication will be able to install the system. Systems specs @ options coming as well.
ElectricSpider
Contact:
Fabricating Motor mount brackets v1.0:
joelittel
Post by joelittel »
Thanks for the updates. I’m a fan of what you’re doing and think we’ll be seeing more and more of this type of mod in the near future.
I haven’t read everything in this thread and apologize if this was previously discussed, but how does the convertible top effect the aerodynamic efficiency? I’m guessing it’s significant if long range is the goal.
ElectricSpider
Contact:
Convertible top make it plain fun:). A little progress..... Motor mount arms will be redone with one piece billet arms (Adpater plate face to stock motor mounts) now that we have the motor alignment. Super easy to drop in when we finish it up.
Hyper 9 Motor and Controller installation....
Looks good with the retro styling and grill....
Rough fitment but wait til we put all the 3D printed parts in and clean this up:)
LED headlights, running and turn signal...
LED side markets all around....
RRoller123
Post by RRoller123 »
Really nice, and the wave of the future. For now, meaning waves follow other waves and are followed by the next wave. You will have one of the original classics in years to come!
ilvecchio
Your car is a: looking for a pre-smog spider
Post by ilvecchio »
The level of attention to detail in the body and interior would be impressive on any car - electric or not.
