1981 Restoration
124JOE
Re: 1981 Restoration
Post by 124JOE »
thats not a crack
if it were there would be a black carbon line
from exh fumes
Fi8spider
Post by Fi8spider »
Divers wrote:Well...removal has started...this should be fun
radiator is out and moving ahead.
Good choice.
I can't wait to see it all sorted, cleaned up and back in place..
Divers
Post by Divers »
After a great conversation with BEEK the other day...decided to post an open ended question about the engine rebuild.
Background -
I do not want nor do I need nor can I afford a race engine :)
My flywheel is out with Jason being lightened and dowel pinned already.
I have the rear seal and bearing already to be replaced.
S0........
What should I do? Let say that I have a budget not to exceed $500 (I will accomplish the labor or beg BEEK for help :)
Thinking about increasing the compression (cheap increase in HP)
......anything else......outside of gaskets.....
Divers
Post by Divers »
WooHoo...
Engine all disconnected and ready to come out! Hopefully next weekend!
124JOE
Post by 124JOE »
cool take some pics 8)
Ky2000
Post by Ky2000 »
Sweet dash... :D
Divers
Post by Divers »
What a freakin mess!!!!!
124JOE
Post by 124JOE »
yes she needs your love
by love i mean MONEY
Divers
Post by Divers »
Luckily I was planning performance valves and such! The head does not bother me that much (until I remove the cam's tonight and then freak out when I see their condition!!!!!!!! UGH!!!!
The pistons are a whole other issue...the cylinders look bad and may have to be bored...which means probably larger pistons to the tune of $400 for HC....YUCK!!!!!
Divers
Post by Divers »
End of a good night of work....
thechadzone
Your car is a: 1969 Fiat 124AS Spider
Post by thechadzone »
Nice clean-up on the head, sorry you found the engine in such a state. Sounds like its on its way to great heights. We're both at a similar place within our engine builds, and I see I'm lucky to have discovered the internals of my 1608 to be in good shape so far...
So did your cams turn out to be usable?
Divers
Post by Divers »
So far everything is just a mess...once clean, the cams looked good. The valve guides even look good, however, I will be changing those also. Started trying to get the block apart, but the crank pulley is killin me.
124JOE
Post by 124JOE »
you can go rent a pully puller at autozone
i did and just kept it $20
it comes with a case that way
