Edit... Resto mod FIRST DRIVE
toplessexpat
Re: Edit... Resto mod coming together
Post by toplessexpat »
Alan - I think you did a just swell job as it is. As for blow drying - you can keep that for your long flowing locks.... ;)
www.mirafiori.com
SoFlaFiat
Post by SoFlaFiat »
toplessexpat wrote:Alan - I think you did a just swell job as it is. As for blow drying - you can keep that for your long flowing locks.... ;)
Thanks Andy! But I will say, it was the most grueling and painful part of the project! The results are rewarding but an easier method would be nice!
I did get door bumpers and door loom in today so spent the last hour rigging some more stuff in the drivers door.
Not completely satisfied with the jamb end mount but I can mess with it later if it drive me crazy. Should have sorted it out before I painted the jambs.
Still lots of stuff to clean up and reinstall in the door. I did get new window regulators some time ago so at least I don't have to clean those.
DieselSpider
Post by DieselSpider »
SoFlaFiat wrote:It is dynamat hood liner. From what I have been told it helps dissipate heat, protects the hood from high engine temps and helps with sound. As with many things on this car, it is an experiment, so we will see.
Meanwhile, I am putting the new door cart to use reinstalling doors ...
One baby step closer to "spring thing"!!
I have been impressed by the Dynamat especially if you put it on the firewall inside the vehicle and use aluminum ductboard tape to join it and seal the edges/openings. On my F53 you could not hold a conversation with the passenger sitting next to you before I installed it and after you have to turn off everything that makes noise and be quiet to hear the engine idling. Heat infiltrating into the cab was dramatically reduced too.
SoFlaFiat
Post by SoFlaFiat »
SoFlaFiat
Re: Edit... Resto mod FIRST DRIVE
Post by SoFlaFiat »
Drove her out of the garage under her own power for the first time in over two and a half years! Wow!!! That's all I've got!!
Took her around the block a couple times. Had to remove the cold air intake hose in the wheel well to make sure that was the source of rubbing. I'll have to reroute that a little. Otherwise, rack and pinion steering slick as silk, brakes need more bleeding, timing needs adjusted, carbs need adjusted and I could use some brake lights but...wow!!
RRoller123
Post by RRoller123 »
Excellent! What a project!
SoFlaFiat
Post by SoFlaFiat »
Thanks!
It sure has been a project, and still lots to do but wow does it feel amazing to scoot around the block! There's no ripping the smile off my face right now! :D
Ptoneill
Post by Ptoneill »
Very very very COOL!!! Congrats!!
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
njoconnor
Post by njoconnor »
YAAAAAY! ROAD DAY AT LAST!!!!
And, uh yeah, brake lights be a good idea!
Congrats, Alan! That first round th eblock doesn't fade soon.....
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
Congratulations!!! I am envious of your talent
toplessexpat
Awesome news.... and you have a hand delivered package enroute!
www.mirafiori.com
AriK
Post by AriK »
One more milestone reached! It's one car that i'd love to see up-close sometime in my future. You have amazing skills!
SoFlaFiat
Post by SoFlaFiat »
Thanks guys!!
A little different story today. I made adjustments and started the car again. This time I have a little white smoke blowing. My best guess is head gasket into cylinder as there is moisture at the tailpipe and no leaks anywhere else. Oil is perfect with no sign of water and water is clear as well. This tells me that I have a leak in the head gasket that is only between a water jacket and a cylinder. Does that make sense?
Ptoneill
Post by Ptoneill »
I had a Porshe 944S that did that......easy fix but still sucks!! Damn Grimlins!
Stay Safe,
Pat
79spider
ptoneill@msn.com
SoFlaFiat
Post by SoFlaFiat »
Ptoneill wrote:sucks!! Damn Grimlins!
+1!!!
