Sometimes the easier way is better: so, a complete change of plan! One piece PVC deflector that connects to only the two inside headrest posts. About $20 for PVC, fiberglass screen, glue and paint. I hope to have it finished and test drive it Saturday. More photos then, and maybe parts list if there is any interest. DIY only, not planning to Mfg. or sell.
Test drive went great!
The secret is to cut 4 - 1/4 - 3/8" wide strips from vacuum or other rubber hose & cut diameter to fit in each end of both "T"s that connect to the headrest rods. This stops rattles & vibration & creates a firmer, more vertical fit. Glue in with contact cement.
More info and parts list in the photo album linked BELOW.
Wind Deflector
- dantye
- Your car is a: all gone
Re: Wind Deflector
- Your car is a: 81 FI 2000
Re: Wind Deflector
Does anyone know if Brady is still making these and his contact info? I cannot find on board listhtchevyii wrote:I've got Brady's roll bar mounted one. It blends into the roll bar very well and is a much more durable mesh than the Raceland ones.
http://www.fiatspider.com/f08/viewtopic ... ind#p95708
- dantye
Re: Wind Deflector
Redux of the PVC conduit & pipe Windscreen: This one is small enough you can close the top without removing it. But still quiets the breeze a lot. EDIT: We took the larger version on our 1300 mile trip to Indiana, and it worked much better - worth the trouble of removing it to put the top up.
Front view:
Rear view:
Front view:
Rear view:
