My fiat project
fiat218
Re: My fiat project
Post by fiat218 »
New valves came Saturday . I will deliver them personally :)
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Re: My fiat project
Post by fiat218 »
my apology to beek
the valve was at the machine shop. i did delivery them, but when he said they where not there then i assumed that i never had them in the first place, so im sorry that i accuse you of not sending them
another question is this , i have marks cams . 410 f i . says on the boxes ( both )
now one cam has a gear on it.what side does it go on, he said he has never seen that so he called to find out
thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
SoFlaFiat
Re: My fiat project
Post by SoFlaFiat »
Cam with gear between 3 and 4 is the exhaust cam. Gear drives the distributor.
fiat218
Re: My fiat project
Post by fiat218 »
SoFlaFiat wrote:Cam with gear between 3 and 4 is the exhaust cam. Gear drives the distributor.
what do you mean between 3 and 4
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
SoFlaFiat
Re: My fiat project
Post by SoFlaFiat »
Sorry, too much info. The distributor sits towards the back of the exhaust cam box, between #3 and #4 cylinder.
In any case, if the cam has a gear on it, it is an exhaust cam.
fiat218
Re: My fiat project
Post by fiat218 »
SoFlaFiat wrote:Sorry, too much info. The distributor sits towards the back of the exhaust cam box, between #3 and #4 cylinder.
ok thanks, he knew what you meant, i just wanted to know :)
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: My fiat project
Post by fiat218 »
What the valve lash ( I think that what he asked) on a cold engine
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
joelittel
Re: My fiat project
Post by joelittel »
If you bought cams from Mark the lash is written on the slip of paper that came with the cams.
It may be listed as clearance, and will probably have an intake and exhaust measurement.
Aftermarket cams do not have the same lash as stock cams.
fiat218
Re: My fiat project
Post by fiat218 »
Where do I find a select case of shims for my head
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
seabeelt
Patron 2019
Patron 2019
Re: My fiat project
Post by seabeelt »
Jim, Buying a case of shims is really un necessary. Once you measure the gap, you can buy individual ones from AR. If you have an old head with shims, all you need is one to put in each location and gap the difference, then order the correct shims for all locations. Just be sure to write down where they go. r/
Michael
fiat218
Re: My fiat project
Post by fiat218 »
seabeelt wrote:Jim, Buying a case of shims is really un necessary. Once you measure the gap, you can buy individual ones from AR. If you have an old head with shims, all you need is one to put in each location and gap the difference, then order the correct shims for all locations. Just be sure to write down where they go. r/
Michael
This are his size
2/ 2.56
2.72
2.77
3.07
3.12
3.23
3.30
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
seabeelt
Patron 2019
Patron 2019
Re: My fiat project
Post by seabeelt »
So, do you know what you need or are you just anticipating based upon putting in the new cams?
fiat218
Re: My fiat project
Post by fiat218 »
seabeelt wrote:So, do you know what you need or are you just anticipating based upon putting in the new cams?
He wanted me to order a 2.55 and 3.00. So he can have a starting point ,so I have them coming
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: My fiat project
is this the same machinist that worked on Steve Mould's engine?
fiat218
Re: My fiat project
Post by fiat218 »
Nope mark, one of his buddy's I believe did his, it wasn't the guy from crookston
But if my memory is right I thought he ordered his head from Vicks, I'm almost positive
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
