No.fiat218 wrote:Was there a factory holed drilled in any stat valveazruss wrote:remember on your initial fill, there is a big air bubble in the bottom hose. It is trapped under the stat insulating it from heat. Until the stat opens, the air bubble doesnt go away. This is the purpose of drilling the hole in the stat valve. It allows the air to escape without the stat opening. This is a closed pressurized system that performs well as long as there is only liquid in the system.
I think this drilling a hole isn't a solution for anything. I'm sorry guys but these cars aren't that hard to fill with coolant.
