Page 4 of 6
Re: A Tale of Two Fiats
Posted: Tue May 08, 2012 8:27 am
by jimmycakes401
I'm interested in hearing response in regards to the stat.
Did you rechrome the heater controls yourself?
Posted: Tue May 08, 2012 6:06 pm
by Zulu
jimmycakes401 wrote:Did you rechrome the heater controls yourself?
No, they weren't re-chromed. I was just lucky enough to find a really good one.
I got some parts from IAP today. The new oil filter feels enormous next to the old UFI one. They say bigger is better, right?
I also put a couple paints on my timing cover. Rustoleum "Sun Yellow" is just the right hue.
Posted: Wed May 09, 2012 10:09 am
by 124JOE
looks good
bigger is better
Posted: Wed May 09, 2012 7:46 pm
by Zulu
Changed the oil today. The new filter took almost a quart of oil!
Posted: Tue Nov 13, 2012 3:33 pm
by Zulu
We finally got around to putting suspension parts
on today. I started with my driver front:
I got stuck, however, with the bottom ball joint. No matter how I jack the assembly, the bolt spins and I can't tighten the nut down. Any advise?
Posted: Tue Nov 13, 2012 3:37 pm
by azruss
remove the nylock nut and use a regular nut to suck the taper into place. once there, you should be able to go back to the nylock to finish the job.
Posted: Tue Nov 13, 2012 3:49 pm
by jimmycakes401
Wow. Look how nice that looks. Mine are still stock. I need to at least replace the rubber some time soon .
Posted: Tue Nov 13, 2012 5:32 pm
by Zulu
azruss wrote:remove the nylock nut and use a regular nut to suck the taper into place. once there, you should be able to go back to the nylock to finish the job.
I tried this to no avail. The bolt still started to spin. Are there any other ideas out there?
jimmycakes401 wrote:Wow. Look how nice that looks. Mine are still stock. I need to at least replace the rubber some time soon .
Thank you! It's difficult not to make it all look nice once you have it all apart. Hence why it's taken so long.
I'd also like to show you guys the heater box I cleaned up:
This was a conglomeration of four heater boxes to create one nice looking one without any broken parts. I cleaned every single part several times and painted the rusted up bits where I could. Finally, I removed the old weather stripping and replaced it with new stuff. It wasn't easy getting it in with uncompressed foam but now it should seal better than ever.
The heater core and valve were purchased from another local Fiat owner and look almost brand new despite their forty years of age. In the future, I plan to replace it with a new core, new valve, and Mark's stainless heater pipes.
Posted: Tue Nov 13, 2012 6:06 pm
by 4uall
Zulu wrote:We finally got around to putting suspension parts
I am in this exact same process
http://forum.fiatspider.com/f08/viewtop ... 14&t=21050
Where did you get the upper coil spring perch?
Posted: Tue Nov 13, 2012 6:12 pm
by 4uall
Posted: Tue Nov 13, 2012 6:16 pm
by Zulu
I took steel wool to my old ones and the zinc-plating polished right up.
Posted: Tue Nov 13, 2012 8:59 pm
by BEEK
did you ever get the lower ball joint to seat? if not let me know ill tell you an easy way
Posted: Tue Nov 13, 2012 9:06 pm
by Zulu
BEEK wrote:did you ever get the lower ball joint to seat? if not let me know ill tell you an easy way
I did not, please do tell.
Posted: Tue Nov 13, 2012 10:03 pm
by BEEK
ok, remove the upper control arm pivot bolt. i see you have the upper balljoint already installed. put a jack under the lower control arm so the spring doesnt become unloaded, or install the shock first. the pull the hub outward while installed on the lower ball joint, it will eventually put enough pressure on the lower ball joint and cause enough drag to install the nut.
or pry down on the upper control arm between the arm and the upper spring perch, this will force the lower ball joint and the spindle assembly together, this will also give enough friction to tighten the lock nut.
i hope this has given you the ideas i am talking about. if you still dont get it, let me know and ill try to be more descriptive and include pictures
Posted: Tue Nov 13, 2012 10:20 pm
by Zulu
BEEK wrote:ok, remove the upper control arm pivot bolt. i see you have the upper balljoint already installed. put a jack under the lower control arm so the spring doesnt become unloaded, or install the shock first. the pull the hub outward while installed on the lower ball joint, it will eventually put enough pressure on the lower ball joint and cause enough drag to install the nut.
This worked perfectly, thank you Beek. We should really get together at some point. Were you at the Alfa show in Celebration last weekend?
