Done!
I only have a few hours in the morning since we have dinner plans with the family... let's see how much I can get done. I hope those exhaust bolts don't give me any trouble....
Engine, after I installed the airflow meter, was running fine. I found out about this because I wanted to remove the oil pan to take out a dent in it. When I removed the oil pan I saw the metal piece you see in the photo, the end part of the auxiliary shaft. Who ever did the last timing belt change forgot to read the memo...Snoopy wrote:Hard work...
Its there some rust on the floorpans ?
The engine running before in this condition ? Whats broken ?
pooldoctorstl wrote:Jaime, You need to start a business called " How To Work On Your Car in Designer Cloths and Never Get Dirty"You could do seminars around the country. Kudos to you, man. I don't know how you do it. Maybe your secret is that you have a full time staff that works on the car and you just stand in for pictures, that would explain how you get so much accomplished on the car in so little time.
On the serious side: Was the broken aux shaft making any noise or indication there was a problem? I know you drove and ran it but that is scary that you could run it like that without it causing more problems.
Jeff
Craig, thank you. It looks great in the photos. I will take some photos of the bad stuff today. I need to check with a body shop to see how much they can fix without having to do a complete re-spray.ga.spyder wrote:Looking good,Jaime!It always amazes me what a little time and TLC will do to transform a car.That dark blue color really looks nice on a Spider.Good luck,
Craig
