185 70 13 b f g,s the advantage. tires were brand new, came off a parts car.
What make/model/size of tires are on your Spider?
It's interesting how everyone has different taste when it comes to
wheels on a spider .
V6spider i read your website looks like you put a lot of work in
that beast on 1 of the pages you said some thing about going
to a track what kind Drag ? and was wondering the HP of the
Chevy V6 with the mod's 300 and your 1/4 times must be fast
with that kind of horse power to wieght .
Dan
Dan
I guess I'll post mine as I'm running 195/45/14 in front and 225/40/14 in back. They are on Borbet T's the rims are 7" in front 8" in back. I have no problems with rubbing and the car is lowered on top of the tires. The tires are Toyo TS-1s. Not a cheap set up but they look the way I wanted them to look.[/list]
I ran 185-70-13's on the rear and stock 165's on the front the last year or so I ran mine. I have since lowered the car w/IAP springs. I need to shorten the panhard rod in the rear a bit to center the axle then I'll see what I have to do in the front. I would like to use the 185-70-13's in front too. I have some 70's vintage 13" aluminium wheels for the car that look period correct. I have to check wheel clearance at full lock both ways. I think they are 5.5" width.
Original wheels
Does anyone have a picture of the original wheels from a '77 model? Or at least know what they look like?
I dont think mine are original, but wanted to check.
- v6spider
Dan... Though I have not officially tested the car... The car will, from a rolling start ( 10 + MPH), light em' up and get up to 3rd before I have to let off the gas for fear off losing it. ... I have also used some sophisticated software engine analzer pro Ver. 3.3 and came up with these specs:bandit wrote:
Dan
http://www.v6spider.com/DynoResults.bmp
