azygoustoyou wrote:Did you figure out what your going to use on the bottom. When do you think you'll have it done? I'm trying to get mine to the point where your at. Just started to strip the bottom.
my wife says i lost my mind
Re: my wife says i lost my mind
i think i'm almost positive i will use por 15 to start, if you look at cost por 15 is about $140 per gallon not to bad and that will be enough to coat the underbody, interior and all chassis parts. Over that i am going to spray undercoating then paint, which i'm leaning towards a satin black. does any one know what the origional paint color was on the bottom ? was it the same as the entire car ?
You might want to check. I heard that paint won't stick to Por 15.
POR15 is almost too hard to sand, they sell a tie-coat primer that is supposed to work, but I've had better luck with the Masterseries brand, it is sold as a primer. http://www.masterseriesct.com/azygoustoyou wrote:You might want to check. I heard that paint won't stick to Por 15.
Trey
- kilrwail
[quote="sgfiat"] Over that i am going to spray undercoating then paint, which i'm leaning towards a satin black. does any one know what the origional paint color was on the bottom ? was it the same as the entire car? [quote]
Although it's a little dirty, I'm pretty sure the bottom of my original '78 is black with factory undercoating. There are some places on either side of the spare tire well where the body coloured paint is evident. So it's possible they painted the whole thing the same coulour as the exterior, then covered most of it with undercoating. But I don't know the actual process followed by the factory.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
On the 72 I just had stripped, the underside was the same color as the rest of the exterior.
