1982 Fiat Spider 2000 restoration project
- royn
Re: 1982 Fiat Spider 2000 restoration project
SoFlaFiat
My goal is to try to get the job as good as I possible can myself. Spending time in the garage is my way of relaxing from everyday life.
I started welding in the side markers and the holes for the mirror. I used some welding supports.
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1159.jpg~original[/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1154.jpg~original[/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1162.jpg~original[/img]][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1163.jpg~original[/img][/img]
My old faithful Esab Miggy let me down. I could probably have it repaired, i will look into it later on.
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1189.jpg~original[/img]][/img]
I looked around for a new welder and ended up buying a good used on, its a Kempi welder. It sat me back quite a while trying to find one, but I am happy i did.
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1190%202.jpg~original[/img][/img]
I have finished the details on the front inner fender and supports and I am now in the process of fitting the fender. This is quite a challenge to me, but I am trying my best.
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1192.jpg~original[/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1193.jpg~original[/img][/img]
royn
Really nice work!!
- royn
Thanks for your nice comments RRoller123 !
I am still not finished welding. Sometimes its good to leave the garage and yesterday was a long drive back to the upholstery shop. I was very excited to see the final results. I have only seen the color i picked in a small color chart.
I must say i am very happy with the result. This upholstery guy have done an excellent job !! It gives me great motivation to speed up the rest of the work
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1203%202.jpg~original[/img][/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1204%202.jpg~original[/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1202%202.jpg~original[/img][/img]img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1206%202.jpg~original[/img][/img]
royn
- joelittel
Great color
- Odoyle
Very inspiring, I like your euro side-marker conversion, it really does change the attitude of the front end.
- royn
Thanks guys for your nice comments !
Finally the front end coming together. Due to previous damage, the hood has been shaved a little to make it fit. I try to weld in some spots to adjust for it. There are a lot of pieces that needs to be welded and adjusted. Very time consuming for an amateur afraid not doing it right.
This is how its looks so far.
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1210%202.jpg~original[/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1211%202.jpg~original[/img][/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1212%202.jpg~original[/img][/img]
http://i1128.photobucket.com/albums/m499/eagle59/1982%20Fiat%20Spider%20restauration%20project/IMG_1214%202.jpg~original[/img][/img]
royn
Wow!!
Body work coming along beautifully and the interior bits look amazing!!
Well done!!
Well done!!
- royn
Hello Spider friends,
Just wanted to say hello again, I am still alive
It`s been way..... to long since I had the time and opportunity to work on my Spider !!
I also see that a lot of pictures on the forum are gone (photobucket ). I have uploaded some old pictures to Imgur and I post as a memory. Hopefully I can come up with a lot of new pictures as work move forwards !
royn
- Odoyle
You are doing a fantastic job! Fender replacement looks well executed. Your interior work is gorgeous too. I assume you used a vinly interior paint to paint the dash and similar trim. I am restoring my 77 in a similar fashion, with respect to the turn signal delete and tan interior. What final color are you thinking on painting it?
- royn
Thanks for your comments. All the interior work is done by a professional upholstery shop and its very nice ! Everything is covered
in leather.
Next I will start to make some brackets for the euro bumpers and weld in the holes. I have not figured out what kind of turn signal to use in the front.
Final color is going to be red, I think !
in leather.
royn
- royn
I finally finished making the brackets to fit Harrington front bumper. My goal was to be able to see the grill and the stainless steel frame, when bumper mounted. I had to cut some metal, to be able to make the bumper fit.
I made the brackets from some solid steel, with holes big enough to make final adjustments.
Ups ! forgot to take picture with the bumper mounted. Coming next time.
royn
- royn
Primed and ready for some paint.
I finally decided to go for acrylic paint and the color is Rosso Corsa !
I painted the engine bay and luggage compartment in my garage.
royn
- royn
I have the gearbox ready and next step is to reinstall engine and gearbox. I just wonder if its smart to do this by rising the car and install
the engine/gearbox and crossmenber in one operation and drop the car down ?
This winter we have more snow than I can remember and shuffling snow has stolen a lot of my time
royn
Really nice work! When does that snow usually melt away? Here in New England, our car season starts around mid-April.
