2.0 with dual carbs
fiat218
Re: 2.0 with dual carbs
Post by fiat218 »
what is this brass tube for ?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Post by fiat218 »
here what they are :)
The brass tubes on your IDF rather belong to a full throttle enrichment system, and are a feature solely found on the 40 IDF 13/15 type (These carbs were stock parts of FIAT Spyder's 1600cc engine back in the 60's). The tubes are meant to work together with the cylindrical velocity stacks that bolt onto the carbs. The principle is very simple: the brass tubes are directly linked to the float bowls. When the engine is operating at WOT, a certain pressure drop compared to the surrounding atmosphere pressure is developing in the velocity stacks. This causes the fuel out of the bowl to be drawn upwards through the tubes and being sprayed into the intake air, thereby enrichening the mixture.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
