1608cc rebuild
djape1977
Re: 1608cc rebuild
Post by djape1977 »
pretty much done...
djape1977
Re: 1608cc rebuild
Post by djape1977 »
problem - bent cam covers
solution
result
hopefully this solves usual fiat's problem, leaky cam gaskets
Daniel
Re: 1608cc rebuild
Post by Daniel »
Hey dj you may want to double up on the valve cover bolt gaskets or grind down the bolts some as well, often times
they bottom out before getting tight which causes the leaking at in least in some cases.
djape1977
Re: 1608cc rebuild
Post by djape1977 »
there you go, that's something i didn't think of. however, cam covers were definately bent as well as 4-5 others i've tried, so i had them machined back to flat. seems to be good now, we'll see what happens once the engine is running
narfire
Re: 1608cc rebuild
Post by narfire »
Daniel wrote:or grind down the bolts some as well,
Now that is a freeking great idea, thanks eh..
Chris
djape1977
Re: 1608cc rebuild
Post by djape1977 »
engine i was talking about finally running
http://www.youtube.com/watch?v=goFnXgYtWm4
SoFlaFiat
Re: 1608cc rebuild
Post by SoFlaFiat »
Nice!!
Gotta love an engine that you can test fire with it sitting on a couple old spare tires!! :D
