Fall/Winter/Spring Projects 2012/13 for Fiona RESOLVED
- focodave
Re: Fall/Winter/Spring Projects for Fiona
Jay,
I feel your pain, man.
My driver's side was difficult like yours.
My passenger side ball joints popped right out -- no problem!
Good luck on it. It's all worth it in the end.
Dave
Dave
1970 MGB GT (my other hobby)
As a note to all, the steering knuckle ball joint bolt holes are TAPERED
I was originally going the wrong direction with my attempted drill outs (broke a total of 3 Colbalt drill bits SOB). The correct way is from the inside of the holes to the outside
Speaking of broken
Does anybody know the best way to fix? Would it be better to replace the whole brake line or can I just put in some sort of compression fitting?
https://www.youtube.com/watch?v=NRHCQgIU_r4
The driver's side front is a very short brake line. I'd just replace the whole thing.4uall wrote:Speaking of broken![]()
- focodave
Jay,
Zulu is right.
Just replace the whole thing.
Compression fittings in brake lines are very dangerous and not reliable IMHO.
None of us want to see your beauty run off the road or hit something due to a failed compression fitting!
Dave
Zulu is right.
Dave
Okay, had a bit of a delay with our Jeep breaking down on the hwy
buying a new car (see signature below
and some school plays
tried to get back on track today only to find out that the parts I ordered from http://www.vickauto.com/newstore/ are apparently NOT the correct parts
I even called and was re-assured when there were rumors floating around that these were not Fiat parts etc. Well, looks like I have learned a life lesson today
Original upper A arm and new from Vick's
(new one had issues with bolt hole line up
New lower shock support does not fit SOB!
THANKS VICKS, I LOVE BUYING "FIAT 124 PARTS" THAT DO NOT WORK/FIT
Putting the frustration aside, I was able to push the bolt sleeve through and cut off the excess to make the shocks fit. Needless to say I will be taking my business elsewhere
bummer, but I can't wait to see your grin when it is all finally done and right!
Hey Jay how did you make out with the brake lines?
have yet to put it in. I was able to pick up some steel brake lines at Partsource and they come with a bubble flare
I also picked up http://www.canadiantire.ca/AST/browse/4 ... ?locale=en so I am all ready. Just trying to deal with the A arms for now then put in the brake line. The best part is that I have to do it all again on the passenger side when I am done LMFAO!
New A Arms installed
Dry fit
LOL assembled incorrectly
Have to grind the new bolt a little
Dry fit
Hi Jay, Sorry to read you had a bad experience with your supplier, Im in the same process as you at present have to admit... my mechanic is doing all the hard work.I don't have the means or space to do anything from home so just like to say hats off to you for doing such a great job.
Parts supplied and installed today, New Crossmember,New Set of 4 A-Arms,New Front & Rear Sway Bars, New front & Rear Lowered 30 mm Yellow King Springs, and New Front & Rear Yellow Konis.
All supplied from Vick Auto, my mechanic was more than happy with the installation, no problems at all, keep in mind that I had to import everything to OZ so we had Gods Blessings.
Keep up the great work Jay as you and others like you inspire me to keep this beautiful car alive
Cheers
John.
Thanks John. Guess I got the ones that were made on a Friday of a long weekend
My issue is that I would never expect new parts to fit in with existing parts without some "tweaking" however, it is beyond frustrating when new parts (that need to be assembled) do not fit properly amongst themselves
Either way moving forward and have learned.
tried to compress my spring with my internal spring compressor AAAAARRRRRRRRRRGGGGGGGGGGHHHHH
Got so far only to have no extender for my 24" socket
Try again tomorrow after visiting the hardware store
rather than give up I thought I would try to install my new steel brake lines, I must have been given the incorrect lines. When I tried to install the line I ran into this little issue
On the left is the new line
You can see on the threads how far in it goes
hmmmmmm
This is as far as they go WTF?!
hmmmmmm
The thread looks the same, but can you measure the overall diameter ("major diameter") of each of them and then the number of threads per inch ("pitch") and compare? Looks like your new one is binding up after 1 thread or so, the pitch is probably incorrect.
