Page 3 of 5
Re: When Working On The Floor - While I'm In There??
Posted: Tue Mar 20, 2012 3:11 pm
by 4uall
I was just about to post. I did not have foam under mine, it was some sort of padding?
Shifter Panel removed by itzebtze, on Flickr
So I was going to put in some EZ Cool instead.
Posted: Tue Mar 20, 2012 3:51 pm
by jimmycakes401
See that metal black part? Did you pull it out yet? The foam is under that. The padding you see there looks like the tar sound deadening stuff.
Posted: Tue Mar 20, 2012 4:00 pm
by 4uall
oh shit :shock: no I have not. Queue music (dumb da dumb dumb dummmmmmmmmmmmmmb) :oops:
Looks like I have more work SOB! :evil: Thanks for bringing it to my attention :mrgreen:
Posted: Tue Mar 20, 2012 4:04 pm
by jimmycakes401
LOL!! Yeah. I was staring at it today and thinking "do I pull that off?" Well. I did. And then I refinished it.
Posted: Tue Mar 20, 2012 4:08 pm
by jimmycakes401
If you find the other foam piece anywhere let me know. I'll let you know if I find it too!
Posted: Tue Mar 20, 2012 4:10 pm
by SanRafaelFaz
jimmycakes401 wrote:Yes. Metal plate, then the rubber inner boot with foam attached to it like 4uall posted. And then the big foam piece. Keeps the noise out of the cabin. If I knew what kind of foam it was I could just cut one out. I have fabric store foam, but I don't want to find it out catches on fire or something with trans heat. The inner boot with foam will need to be ordered. :(
Ahh, I see. I didn't go below the first metal plate. I can see the foam under the next plate, though.
Posted: Tue Mar 20, 2012 4:25 pm
by 4uall
Posted: Tue Mar 20, 2012 4:42 pm
by jimmycakes401
Wow I've been googling foam and shifter all day. That is a great post that I did not come across.
Posted: Tue Mar 20, 2012 4:55 pm
by jimmycakes401
Although. That doesn't help me find foam for under the shifter metal plate thingy.
Posted: Tue Mar 20, 2012 5:18 pm
by Exit98
I didn't have that foam piece under the metal plate on my 76. I pulled it off to replace the inner shift boot. Then when I reinstalled it i put a piece of my self-adhesive insulated aluminum insulation under the metal plate (aluminum side facing down towards the transmission) then screwed the plate back down, making a sandwich of the insulation.
I had already removed the tar stuff and went on to insulate the entire center hump and floor with the insulation.
Posted: Tue Mar 20, 2012 5:34 pm
by jimmycakes401
Looks like a space ship. Good idea with the insulation. Maybe I'll go that route. What sound proofer did you use there?
Posted: Tue Mar 20, 2012 5:59 pm
by SanRafaelFaz
Exit98 wrote:I didn't have that foam piece under the metal plate on my 76. I pulled it off to replace the inner shift boot. Then when I reinstalled it i put a piece of my self-adhesive insulated aluminum insulation under the metal plate (aluminum side facing down towards the transmission) then screwed the plate back down, making a sandwich of the insulation.
How did that effect the placement of your carpeting? I just ordered a new set from Stock Interiors and they said that other than the hump area, anything over the bare metal floors might be too much for the tight fit of the custom cut carpet pieces.
Posted: Tue Mar 20, 2012 9:24 pm
by Exit98
Jimmy,
Here's the insulation I used. Good price, I like the self adhesive. Very easy to work with and it sealed so well I found no need to tape the seams. Got it here:
http://www.ebay.com/itm/250990147823?ss ... 1439.l2649
Faz,
I bought cheap pre-cut carpet. Not thrilled with the quality, guess I got what I paid for. With the floors done now I can always put in better stuff some future time without it being a big deal. I used spray adhesive for all the side pieces. Think I'll use velcro and maybe a screw or two for the flat parts so I can take them out to clean easily. If that doesn't work and they shift around too much I can always glue them later. Doesn't seem to be a problem installing them over the insulation. It's only about 1/4 inch thick.
Here's what I bought:
http://www.ebay.com/itm/390361681491?ss ... 1438.l2649
Posted: Tue Mar 20, 2012 10:09 pm
by DocGraphics
Exit98, how would you compare the fabric/quality of the carpet set you got to the indoor/outdoor cornrow carpet from like Home Depot.
Posted: Wed Mar 21, 2012 12:53 am
by 124JOE
anyone looking for foam
go to a fabric store
ask about bed pads
or chair padding
youll see something real close
get it and cut it to fit
