HELP PLEASE
Fiat88
Re: HELP PLEASE
Post by Fiat88 »
124cso wrote:
Baz wrote:I have done the same sort of thing with the engine hood. Ran a light wire from the lock through a small hole accessible from the front wheel well. Works great in case the interior cable breaks.
Baz
Sorry, but I have to say it " DOH" "DOH" "DOH" !
If you have a look at your car or at your handbook or at your workshop manual, it will show you that they installed just this "safety devise" at the factory.
It is normally a simple loop tied in the end of a piece of grey/gray coloured/colored plastic coated cord, you should find tucked up under the dash above the pedals / behind the column. Assuming that some bozo has not thought 'what's this junk" and cut it out !
I had to use mine last month for the first time because when I got the car back from a shop(not going there any more), when I got home to open the hood there was no tension. I was like oh sh*t! :x Then I remebered the grey emergency cable and the crisis was avoided. :D I found the hood cable disconnected from the latch. The only explanation I could think of was that because I have trouble closing my hood, the mechanic must of been playing around with it and forgot to hook it back up.
124cso
Re: HELP PLEASE
Post by 124cso »
[/quote]
Assuming that some bozo has not thought 'what's this junk" and cut it out ![/quote]
I had to use mine last month for the first time because when I got the car back from a shop(not going there any more), when I got home to open the hood there was no tension. I was like oh sh*t! :x Then I remebered the grey emergency cable and the crisis was avoided. :D I found the hood cable disconnected from the latch. The only explanation I could think of was that because I have trouble closing my hood, the mechanic must of been playing around with it and forgot to hook it back up.[/quote]
Isn't it so often that when we have trouble, it can be traced back to some CRETIN (mechanic or previous owner) meddling with things ? or modifying for no good reason ? I hope you have given them an earfull ! And they probably charged you for the time to uncouple that wire too ???
