Spider Fuel Lines
Not that I plan on doing this, but if I were to get stainless braided lines and they needed to have an end where they "push to connect" like on the carb or something. How would I clamp that on there without fraying and whatnot. is it one of these magnaclamp things? Actually, if I did something like this it would be that bit of rubber tubing under the car that connects to the steel fuel lines (and then I'd probably use screw to connect fittings). I'm wondering if having just plain rubber tubing (Polyester reinforced of course) will be durable enough. How durable are these stainless steel braided lines you see on ebay anyway?
