Can we talk 124 Coupe?
RoyBatty
Re: Can we talk 124 Coupe?
Post by RoyBatty »
Hi John,
Paint and body work are going to be a slow progressive type thing.
Here is a short clip from my phone to give you an idea of the sound. It's much better in real time tho.
https://youtu.be/VfUDo9vfwUo
By the way, what size wheels did you get from Allison's and what size tire are you using?
Redline
Your car is a: formerly a 1971 Fiat 124 BC Coupe
Post by Redline »
Just a little tip for you to file away in the back of your head (as I was pulling my hair out until I found the fix). The IDF throttle shaft runs in ball bearings which are sealed by the grease and sometimes a leather seal. With age, the grease can dry out. Not only does that make the shaft less smooth in its action (not really noticeable), but more importantly it lets air leak into the carb, causing all sorts of weird problems that are impossible to fix without stopping the leak first. A new set of sealed bearings in mine cleared a lot of stumbling and flat spot problems.
http://www.124bc.com
RoyBatty
Post by RoyBatty »
Hi redline,
Thanks for that.
Yes, in all my internet research about the idf's I had read about that being a potential problem.
When I dipped the carb bodies, I was very cautious to avoid getting the shaft bearings in the soup.
I found that this pair of carbs were more easily dialed in than the pair I installed to the 1800 in my spider.
Could it be that installing them to the spider actually gave me some useful experience?
RoyBatty
Post by RoyBatty »
YES!!!
Thanks to chrisg for being kind enough to sell me this perfect NOS drivers fender.
Very nice packaging job using a bicycle shipping box.
Oh and I also purchased a nice set of sun visors from him.
I wonder if there are many more of either of these to be easily found left in the world?
RoyBatty
Post by RoyBatty »
Progress,
Crap, going to have to wait to link pics from my pc at home.
After the temp repair it was like this,
Now I start fitting the repair panel,
Had to drive it,
Back to work and after some grinding,
Ready for final bodywork prior to paint, after I clean up some rust on the passenger side,
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Nicely done!
