With air conditioning:
Without:
Doesn't running te A/C add some additional engine heat? I live in TX too and saved the aftermarket A/C unit - does your car run OK temp wise, even stuck in traffic in the summer? I had an auxiliary fan installed in my car (it's an automatic) and still had to pull over a time or two when stuck in traffic; not sure if this is just the way it is w/an automatic Fiat in TX.pastaroni34 wrote:I make the brackets to install a modern compressor on the exhaust side of the engine. The rest of the components for A/C are fairly generic. It's a nice addition down here in Texas!
What kind of compressor is the bracket you make for ? and how much i've been thinking of doing thisI make the brackets to install a modern compressor on the exhaust side of the engine. The rest of the components for A/C are fairly generic. It's a nice addition down here in Texas!
