Mathew26 wrote:Hey guys those Topsonline tops are good quality material (as Haartz always has been). I have personally looked at them versus a few other tops. Some things I've noticed that you may want to be aware of...
1. the stitch per inch count is on the lower side compared to other tops
2. the rear window was stitched in rather than heat seal&glue (i'm sure there was some glue though)
3. the flap that sits to the top of the door windows is cloth rather than vinyl, which means if you get caught in the ran it will leak
I can't speak for the rest but the tops out there but the one I have has the same HAARTZ cloth material for the flaps. I've had it in heavy rain 3 or 4 times now and it hasn't leaked at all.
I'm sure it's not going to last as long as a $500 top but then again it's half the price, looks great, and has a 5 yr warranty. I look at it this way... the plastic window is going to go before anything else so your probably going to replace the $500 top after 10-12 years if your lucky anyway. If you get 5+ yrs out of a $250 top its a wash.
And, if the cheapo top disintegrates after a year of use then, well... lesson learned.
