Risen Engine
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: Risen Engine
Post by wachuko »
ralphcap wrote:Duh! I changed the photo bucket folder to post pictures of my car to "New Member" section. I'll try to repost the earlier photos of the tranny mount, engine comartment and shift lever. Gotta learn how to post directly to reply post.
I saw your photos earlier, and I am with Halg... your transmission crossmember is not right... clean, it should look like what Halg posted... dirty, it should look like this :D
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
wachuko
Contact:
Re: Risen Engine
Post by wachuko »
As to posting the photos...
In the post a reply screen you have a button that says img
To post the photos all you have to do is put the link to the photo between those codes (eliminate the " from the following )
"["img"]" link "[/"img"]"
Drive Safe!
Wachuko
2015 FIAT Abarth
ralphcap
Re: Risen Engine
Post by ralphcap »
Ok here are the photos I originally posted. I provide more late night laughs than Jay or Dave.
http://pbckt.com/sS.lh3
wachuko
Contact:
Re: Risen Engine
Post by wachuko »
Can you see the difference?
Yours (bent):
Ours (dirty, but straight):
Drive Safe!
Wachuko
2015 FIAT Abarth
Re: Risen Engine
If you hit something while driving it would be twisted back, and ripped the studs out of the floor pans. That damage resulted from the car being supported or jacked up by that bracket. Place a jack under the flat spot on the trans just before the guibo and remove that bracket before you over stress or tear the rubber.
Let me know if you need another one, I got a couple.
matt.scarton@gmail.com
ralphcap
Re: Risen Engine
Post by ralphcap »
Ok. Here are the photos I originally posted. Sorry for the "Duh"'
ralphcap
Re: Risen Engine
Post by ralphcap »
Thanks to everyone. No wonder it was such a struggle changing the transmission mount! Heh, the dents were symmetrical! I thought it was designed that way! Ok, so my IQ is 2 above plant life.
ventura ace
Re: Risen Engine
Post by ventura ace »
The other cross-member support behind the tranny mount seems to be mounted upside down, also.
Alvon
pope
Re: Risen Engine
Post by pope »
The rubber area on the mount looks different. There is something hanging down there. I cant believe that a replacement part would be made to hang down 2" lower than the mount bracket? Anyone seen this before/
wachuko
Contact:
Re: Risen Engine
Post by wachuko »
pope wrote:The rubber area on the mount looks different. There is something hanging down there. I can believe that a replacement part would be made to hang down 2" lower than the mount bracket? Anyone seen this before/
I saw that as well but thought it was either the rubber mount broken or stretched beyond normal...
Drive Safe!
Wachuko
2015 FIAT Abarth
wachuko
Contact:
Re: Risen Engine
Post by wachuko »
ventura ace wrote:The other cross-member support behind the tranny mount seems to be mounted upside down, also.
Alvon
Wow! That is where the bridge for the drive shaft goes...
Drive Safe!
Wachuko
2015 FIAT Abarth
ralphcap
Re: Risen Engine
Post by ralphcap »
Y'all are great detectives. Here's my confession. The damage to the crossmember was the result of one of two events or maybe both. First, several months ago my drive shaft separated from the differential and I had to drive about a block before I could pull over. I had it towed home and after inspection (by a novice, me) I just bolted it back up and away I drove. Second, as Matt diagnosed, I've been jacking the front end up using the transmission mount crossmember! There, I feel a lot better! Now, am I missing some sort of a bridge?
ventura ace
Re: Risen Engine
Put your jack under the main crossmember, the one under the engine oil pan. Use a block of wood to help spread out the load. This is the only 'bridge' that you should use for jacking purposes.
Alvon
wachuko
Contact:
Re: Risen Engine
Post by wachuko »
ralphcap wrote:Y'all are great detectives. Here's my confession. The damage to the crossmember was the result of two events or maybe both. First, several months ago my drive shaft separated from the differential and I had to drive about a block before I could pull over. I had it towed home and after inspection (by a novice, me) I just bolted it back up and away I drove. Second, as Matt diagnosed, I've been jacking the front end up using the transmission mount crossmember! There, I feel a lot better! Now, am I missing some sort of a bridge?
Well, maybe I used the wrong choice of words and made a mistake. I thought I was looking at the third bracket...
Pardon the rust, here is a photo of the area:
Your transmission mount bracket (1) needs to be replaced. The second bracket (2). The one upside down, needs to be installed correctly. There is a third one (3) that has the drive shaft support (the one that holds a big bearing).
Drive Safe!
Wachuko
2015 FIAT Abarth
pope
Re: Risen Engine
Post by pope »
LOL, I dont know whats worse, italian rust or owners? LOL
