Wind Deflector
Re: Wind Deflector
yes, Ron's plexiglas design is great, but i did some modification to it. i added a 1x2 between the seat back and the bottom edge of the plexiglas to reduce the "flutter" of the plastic due to wind buffeting. it works great with the modification. although, it does cause the seat to bump on occasion in strong wind conditions. properly done... it is about $200.00 cheaper than the black nylon mesh unit sold to fit our cars.
i also have one of those, sold by IAP. my wife and i love it, it works great without any bumping of the seat back. if you haven't a roll bar and can afford the cost... this unit is great.
Re: Wind Deflector
Mike,
Do you have the IAP one installed in a car? If so, would you be so kind as to snap a quick picture or two of the mounting points and hardware. The one I have is missing the hardware on the ends to mount to the top frame and IAP doesn't stock it. Before I start to fabricate homemade brackets I'd like to see what the originals look like.
Any help would be greatly appreciated.
Thanks,
Rick
Thanks,
Rick
Re: Wind Deflector
rick,
i do, but that car is in storage. i won't see the car for a full week, and won't be dropping the vinyl top anytime before May. i won't be able to snap a picture before the top drops. it is too cold here to expect that vinyl to cooperate w/out cracking or tearing.
the brackets ARE extremely simple, and are designed to attach to the shoulder bolt that acts as a pivot for the center section of the convertible top frame. look at the frame mounting location.
the bracket for the deflector will stay in the same position, regardless of the action of the 'vert frame. (top up or top down, the deflector stays in the same position.
wish i could say it better than that, but i am an accountant ... not an engineer. Bright guy you are, you should be able to figure it out.
the deflector looks nice installed, and worth the effort to design a proper bracket.
or... you could wait until i get my car out of storage
Re: Wind Deflector
Mike,
I keep forgetting that you guys up north store your cars for the winter. Dont worry about the pic's I think I have a good visual from your description on what I'm going to need to install it. I'll get back to you in MAY if I cant figure it out
Thanks,
Rick
Thanks,
Rick
Re: Wind Deflector
picture this:
|<--the shoulder bolt goes here per my previous comments.
| ___
|__| |<--the deflector mounts here
a b
the bend at the bottom (a) is deep enough for the folded frame to sit inside the pocket w/out disturbing the wind deflector bracket.
the bend in the middle (b) goes over the inner wall and the rear plastic quarter panel. i think the two mounting holes are approximately 8mm. the brackets (one for each side) are symetrical mirror images of each other. like i said, i am an accountant, and this is from memory. i dunn draw well, but can pour a mean glass of brew!
hey... here's a thought. I am having a garage day on January 30th. stop on up and i will buy you a beer, and you can see the brackets in person.
| ___
a b
- Your car is a: 1972 124 Sport Coupe
Re: Wind Deflector
The spider is in Dallas, and I won't get there until Saturday. I'll snap some pics of the mounting hardware then. I have not noticed any flutter, and it sits farther back from the head rests than it appears in the photo. I have never felt anything on the head rests.
Re: Wind Deflector
Mike thanks for the description. If I ever get up that way I will take you up on that beer! Guiness Draft of course
sptcoupe, I wouln't mind some pics to if you have them.
Rick
Rick
- Makita
Re: Wind Deflector
My Spider have a wind deflector, bought it in last summer from Germany.
http://www.nic.fi/~makital1/spider/2009_tuulisuoja.jpg
Here is fitting instructions
http://www.chromdesign.de/pdf/ep30062w.pdf
Pininfarina Spidereuropa -84
Fiat 850 Coupe -66 (project)
Alfa 156 2.0TS -98
Alfa 156 2.0TS -98
- Makita
Re: Wind Deflector
The brackets are simple
Alfa 156 2.0TS -98
Alfa 156 2.0TS -98
Re: Wind Deflector
I have one home made plexiglass wind deflector and it work well. It's a family's project and it could be changed for some details but, for me, It's works great. I didn't any extra hole and i used attacks of seat belts. If someone want more info, ask me.
Re: Wind Deflector
I was reading posts on another board about wind and noise when driving open cars and various posters brought up the importance of wearing hearing protection while driving with the top down. Even simple, disposable foam inserts in your ears can do a lot to help to protect your hearing. Of course, it would also be important to do this when working on a running engine. Just a thought I wanted to share.
George
George
Re: Wind Deflector
I wear ear plugs when I ride my motorcycle also. Otherwise I wouldn't be able to hear your posts.
When I get my car running. I definitely will have some in my glove box especially for the kids.
Re: Wind Deflector
I started investigating an alternative cheaper wind deflector as I have the expensive one from IAP on my Alfa Romeo Spider. I found that Raceland (website http://www.Racelandus.com) has a Windblokker for a Mazda Miata. They emailed me the dimensions and after verifying this will work for a Fiat Spider, I ordered one. I will make the brackets based on Makita from Finland's above picture and let everyone know how it looks and post some pictures. The quality of the screen is about the same as the IAP one but much cheaper at $39. I told the Raceland folks to expect many orders from Fiat Spider owners so they may make the brackets eventually (they now make Windblokkers for MGB's based on many requests from that forum).
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
Sylacauga Alabama
Re: Wind Deflector
I bought my Dad one of the MGB ones for $59. Quite a deal, although the sceen is pretty fragile and they don't package them very well, (It took two before I got a good one and from what I saw at the Brittish car forum that's pretty common). They have some pretty cheap roll bars that don't fit our cars too.
Trey
