Installing fender flares
Re: Installing fender flares
I cant tell but is that floor black with white squares or white with black squares?
The other day I had "googled" fiat abarth and several pictures showed both. Some were rivited on and some seemed to be blended in. I guess whatever works.
Trouble with having black on the floor is if you drop a dark washer or nut, you have to hunt for it on the black squares cause they will never land on the white where you might see them quickly. Kind of finding the center of the car, nut rolls to the center just about every time.
That car does look nice as does the shop. I have to admit, mine is a bit of a disaster at the moment, two fiats,running gear for the third,and a ton of fiat parts as well as woodworking equipment blended in for contrast.
It doesn't matter what color my floor is. Those things just disappear. It's like you hear it drop softly right below you and hear it ricochet across the room three or four times...
