IDF Toys
lanciahf
Re: IDF Toys
Post by lanciahf »
Its alive!
Installed IAP 40/80 cam on the intake and degree-ed both cams to 110 degrees overlap using Millers Mule Adjustable Cam pulleys. I sill need to play with the carb balance tool.
I'm close but not quite there. I was so surprised the motor idled that well.
http://www.youtube.com/watch?v=UsZSuXexEm8
azygoustoyou
Re: IDF Toys
Post by azygoustoyou »
Nice!
mdrburchette
Re: IDF Toys
Post by mdrburchette »
Sounds like you have a little rough spot but you'll work that out once you have everything balanced and dialed in. I was also surprised at how smooth my 1608 idles with the dual IDFs and 42/82 cams. 200% better than with the 2bbl Holley.
