This is getting perplexing. When the engine reaches this "binding point", what happens if you try to turn the auxiliary shaft pulley at that point?carpenduh wrote:So pulled the fuel pump loosened up the cam boxes and took the timing belt back off. turning the motor over by hand I can get to TDC in one direction but shortly after the binding still happens and it will not turn over any further. The same thing happens turning the opposite way, something is still binding at about the halfway point between the combustion and exhaust phase of the number one cylinder. From listening at the top of the motor it sounds like the bind is bottom of the motor?
Based on what you've tried, the problem is not the fuel pump lever, or valves hitting, and I'm assuming the spark plugs are the right length (you could remove just to make sure this isn't an issue). The only things left are an issue with the auxiliary shaft, or something wrong in the bottom of the engine. And you do have the transmission in neutral, right...?
Do you have the distributor in the block (rather than the later style of on the exhaust cam)? Any chance something in that is hanging up?
