Glad you got it apart! And yes, you have the early style with the solid square metal rod. I don't know what year Fiat switched to a hollow tube, but probably mid-70s.adavis wrote:This time I loosened the screws on the non-clip side (opposite the reclining knob) and as soon as I loosened the second screw the bracket came loose. The rod (solid square) then slid easily out the hole after the bracket was removed.
Even better, you have an intact seatback release lever! That little plastic tab that unlocks the seatback so it can be tilted forward. Take care of that bad boy, as they often break and are hard to find. I'm looking for one or two myself.
As for the clip, it looks to me like it was pressed on with a pretty heavy-duty hydraulic press when originally assembled. I've never messed with it. Clean up the ratchet mechanism, squirt some lithium white grease in there, and you should be good to go.
