Lower Radiator Hose / Flushing Cooling System
- moss1972
Re: Lower Radiator Hose / Flushing Cooling System
Todd that was an awesome illustration, thank you for posting that! There is so much great information out there. Some of it you only find after but that's half the fun and really increases the learning experience. Thank you again for sharing!
Steve
MA/NH
1979 Spider 2000
MA/NH
1979 Spider 2000
You are quite welcome! Glad that it helps!
It's my pleasure, since a lot of folks do not have access to the Fiat Spider Shop Manual,...I bought mine twenty years ago. They're a bit more expensive now, but I find mine to be invaluable,....
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
The hole drill in the t stat is a good option. I have read at some point and I can not recall when or where..... Fill the system and insert a flathead screwdriver in between the t stat and hose and use that to purge air. Personally, I've not needed to do this after filling the system from a high point "T" before hose goes through firewall to the heater and run a few cycles. However, it does seem to make sense in a jam if you have air trapped there.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- moss1972
Yes that is exactly what we ended up doing. Great trick! We did my brothers 79 this week and had no problem squeezing out the air in the lower hose up into the radiator.TX82FIAT wrote:The hole drill in the t stat is a good option. I have read at some point and I can not recall when or where..... Fill the system and insert a flathead screwdriver in between the t stat and hose and use that to purge air. Personally, I've not needed to do this after filling the system from a high point "T" before hose goes through firewall to the heater and run a few cycles. However, it does seem to make sense in a jam if you have air trapped there.
Steve
MA/NH
1979 Spider 2000
MA/NH
1979 Spider 2000
Neat trick I found if you can loan one of these from your local auto parts store (or you own one):
https://www.oreillyauto.com/detail/b/ev ... 85/4700282
Fill up the system. Just dump it all into the radiator.
Use the above tool to pressurize the system to 16 psi (or whatever your cap is rated for). Wait. Slowly release the pressure, you'll hear it gurgle and spit. Do that again, three times. Pressurize, slowly let it out.
Pop off the tool, top off your radiator. You're done.
Cheers
Steiny
Cheers
Steiny
- moss1972
That’s fantastic, This is going to be a fantastic resource thread for people in the future.SteinOnkel wrote:Neat trick I found if you can loan one of these from your local auto parts store (or you own one):
Cheers
Steiny
Steve
MA/NH
1979 Spider 2000
MA/NH
1979 Spider 2000
Now I should note that I also have a hole in the t-stat. Not sure if that is relevant or not.
I've never replaced my 1979 Fiat T-stat. It works perfectly and I've never had to resort to the gyrations that you guys describe. I follow the Shop Manual recommendations. Fill the radiator and cap it, fill through the passenger's side upper hose (at the coolant T), and then complete the fill from the coolant T's bolt.
I have to add about a cup of coolant to the reservoir after warming the engine, but that's it.
At least ONE THING is easy to get right, every time, on my car!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
