81 timing mark question
- aj81spider
Re: 81 timing mark question
I did the same as you RRoller, but I found a connector with a cover. Those connectors are sometimes used for battery tenders and there are lots of extension cords available on Amazon. I found one with a cap and cut it to length and wired it into the car. The matching end is on my timing light.
A.J.
2006 Corvette
2006 Corvette
Nice, I may look for a cover. The connector I used is a standard trailer rear lights connector. We can compare notes at Tutto.
Pete
Pete
- Patron 2019
Any reason not to just use the 12v terminal on the coil?
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
No coil terminal with the Computronics unit.
Coil terminal is what use but I have the standard electronic ignition.
- Patron 2019
That would be a reason!RRoller123 wrote:No coil terminal with the Computronics unit.
Previous 76 Spider
Previous 76 Spider
