Cam timing 101: Will this engine run?
ORFORD2004
Re: Cam timing 101: Will this engine run?
Post by ORFORD2004 »
I just check my cam. With lobe 1 down and lobe 4 up, your cam pin should be just past the cam tower mark.
Look like you need a cam or a different pulley.
Spider951
Post by Spider951 »
I decided to open up back end of cam towers from '82 engine (you know, the one with the UFO camshafts). Here is what I found (exhaust in attached photo). Looks like they are Reed cams. Exhaust says "Reed I9073 SA39 EX"; Intake: Reed I9074 SA39 IN". Does this mean anything to you camshaft experts? Only thing I've found is that they are probably old - Reed no longer around. Apparently Reed cams were used by hot-rodders back in the day (??). What they are doing in an '82 Fiat engine - who knows.
IMHO there are a few options, including: (1) try this '82 engine as is (I have already replaced cam seals, timing belt, new aux pulley, etc), (2) make more of a Frankenstein engine out of it by replacing the Reed cams with the cams from the '81 engine , (3) try to find some professional help, i.e. clean and rebuild entire head from one of these engines ($ option), (4) just buy a rebuilt head from one of our vendors (even more $ option). I'm pretty sure the cyl head from '81 needs at a minimum new valve guides and seals, etc. from the amount of blue smoke when cranked (and carbon buildup I can see). Any info/advice will be appreciated.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
I am from atlanta, where REED cams was located. They made / ground many sets for me. I dont remember the grind numbers but everything they did for me was a class act. I used them for years
75 spider
son has 78 spider
