engine paint durability report
As for the engine paint, did you just use the spray cans, or did you buy it by the can, and spray it with a gun?
If you used spray cans, how many did it take for the engine block? And how many coats did you use for the paint and the clear?
Did you lay a primer? (If so, what kind? I didn't see any high heat when I bought the paint and clear)
What did you clean the bare metal with before spraying? The can doesn't say anything, and I'm not sure if mineral spirits will cause a problem
here is the paint i used
it only takes one can of paint to do the block. i did 3 coats. then a can of clear to seal it. i didnt primer it , but i could have, they have an engine primer paint too. i cleaned the parts with simple green. then rinsed and dried completely before paint.
i got the new linkage roughed in yesterday. went to pick a part and took the carb likage off a geo metro, i knew those cars had to be good for something. lol. still need to fab some brackets. when i get the brackets done, i will take them to a friend to see if he can make copies of them that are worth looking at....
while, its 3 months later. time to work on the car again. people have been calling the last few days and asking what im doing. i told them i was cleaning my rear end. they said ,WHAT! i had to explain that it was the automatics geared rear end for my car. it was a mess. spent 3 days trying to clean it with wire brushes and wheels. then got smart and bought a troy built 5 horsepower honda engined pressure washer. was done in under an hour. now i just need to repaint it and install tha 5 braided brake lines i got from mark. will post pics tommrow. also installed new rear single tube muffler. hope to be done in 2 weeks for local show. would also like to drive it to the dealer when i test drive the new turbo soltice.
while believe it or not. i actually found some time to work on the car again. found the eclipse hood i needed to modify my hood with. i cut the bulge out and laid it on my hood. i think it looks awesome. just need to find a good metal man to install it now. also removed the master cylinder, brake booster. clutch cable and stock pedal. i am installing a later pedal set up on the car. easier to modify later. also thinking about changing out the brake fluid resivoir. had to cut it short today so i could do a brake job on some kids 626, man, if i charged every timy time i fixed someone elses car, i could afford to finish mine. Oh well later.
