My cracked dash repair
srwilson
Your car is a: 1979 124 Fiat Spider 2000
Re: My cracked dash repair
Post by srwilson »
Wow! Great job!
Yes, tell us more about your process and materials used.
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
DieselSpider
Post by DieselSpider »
younkin1 wrote:DieselSpider!
What was I doing wrong? Thanks a lot buddy!!!
Clearly I'm a newb.....
You are imbedding them twice over:
Image[/img]
Image[/img]
Just declare Image once at the end of each image URL and they will display just fine.
All I did was delete the duplicate Image
younkin1
Your car is a: 1982 Spider
Post by younkin1 »
georgeramos wrote:What is the proper vinyl and what filler did you use?
Thanks, great job!
Hi georgeramos,
The body filler is as I mentioned above it called Evercoat Everglass short strand body filler here is a link-
http://www.evercoat.com/productDetail.aspx?pID=36
The vinyl I used is made by a company called AllSport Vinyl. Here is the link for the company I bought it from locally. http://www.rochfordsupply.com/shop/Text ... index.html
wizard124
Post by wizard124 »
Beautiful job!
I replaced mine but kept the original, cracked and warped. I just might try your techniques just for the heck of it!
srwilson
Post by srwilson »
Thanks for the links!
What type of adhesive did you use and did you have to apply heat to get it to form properly?
-Steve
younkin1
Post by younkin1 »
srwilson wrote:Thanks for the links!
Hi Srwilson,
The adhesive is a 3M product, link below. Also yes, you will have to apply heat when laying the vinyl down. You need heat to work it into the recessed areas and that takes some time and heat. Like I said in the beginning of the thread, I didn't work out from me the first time. The result you see is actually my third attempt. One suggestion is work the face profile first allowing the material to relax down and then work it over the top of the dash, lapping at least 1" over the edges to secure the vinyl. Once these areas are down, smoothed out and secure, I then worked all the recessed areas in with heat. You'll need to make a slit almost in the center of the vinyl to release the material tension. But be careful to not come too close to the open end of the dash because that is the material you'll need to cover those recessed area. I hope this helps you.
http://www.amazon.com/3M-Marine-8090-CO ... B002IV4M8K
srwilson
Post by srwilson »
I went back and read your original post and see that you addressed my questions there. Sorry about that. I was distracted by the pictures I guess. :?
-Steve
younkin1
Post by younkin1 »
Hello Everyone-
UPDATE- I finished re-cover that dash about one month ago and since then it has sat on my workbench. I was fitting the vents and realized there were a couple of area that lifted and bubbled up. So this means I have to redo it once more :oops: But before I do I will have to do a little more research and see if there is a better adhesive for this type project. Thinking maybe 3M's Super 77 adhesive might be better? Do any of you have suggestions?
Bunnet
Post by Bunnet »
That amazing, I may have to just try that but fear my skills not as good as your. Would you give more detail explanation of how you when about doing it?
dbr
Your car is a: 1981 fiat spider
Post by dbr »
Did the body filler ever crack in the sun? I tried doing this awhile back but after I had finished I thought I would test it before I reinstalled my dash. So I left it in the sun for 30min. and came back only to find that the foam had pulled away from the body filler. I am newb.. so I probably made some stupid glitch somewhere along the process.
v6spider
Post by v6spider »
This is outstanding! If you wouldn't mind detailing the materials you used most of us here would be very greatful. Specifically the exact vinyl and filler used would be very helpful. I see the adhesive is still unsure 3m seems to be best anything that is permanent.
Thanks!
Rob
http://www.v6spider.com
jpaulus53
Your car is a: 1977 fiat spider
Post by jpaulus53 »
Thats the best dash repair i have seen. Great job.
