valve shim thickness
engineerted
Your car is a: 1974 124 spider
Re: valve shim thickness
Post by engineerted »
That grind is a typical 40-80 grind or PBS L1. 10.3mm lift. I hope you didn't pay more than what IAP sells these cams for?
Two thumbs up for the Ross pistons, I run a custom set in my race car, 13/1 very nice units.
Ted
Wfolland
Post by Wfolland »
Still thinking about what headers to use, trying to understand what issues I'll be running into with putting the 2L in my 1970 EuroSpider. Must make a decision sooner than later as the engine will be going on a dynometer once build, any suggestions?
