I would try that.
.JOE
Fuel return line
- 124JOE
Re: Fuel return line
If it runs ok now then you may not need to. It may help if you have vapor-lock problems.RoyBatty wrote:...Would it be better for me to go ahead and install a restricted fitting in the back of the rear idf and connect that to my return to the tank?
- RoyBatty
Probably best that I don't try to fix that what ain't broke then.
OK I installed one yesterday and put some miles on the car last night and this AM. That gasoline smell in the garage is completely gone now and it no longer has to crank to refill the carb bowl before starting in the AM. Thanks for the cheap and easy upgrade.
- 124JOE
any time
