Intermittent problem...any ideas??
ga.spyder
Re: Intermittent problem...any ideas??
Post by ga.spyder »
I should have updated this long ago.Problem has been resolved,and it was the ignition switch.I went to the garage and started the car ,and it immediately cut off.Yes!!!! I checked several things to no avail.I fiddled with the switch and it started up.I found the connector scorched at the main power wire.As a temp fix,I bypassed the connector and soldered the two wires together.Made a drama free ride to Italian Car Day and back.....and took home the trophy for Best Fiat !!!
Craig Nelson
Fling It Around Turns !
