Temp. Guage
rlux4
Patron 2022
Patron 2022
Re: Temp. Guage
Post by rlux4 »
I'm away from the house right now so I can't look up the answer to your question, but do you have the wiring diagram Brad Artigue has for download? He makes it available free, and in a very versatile format. If not, find it here, it really helps in tracing wiring problems: http://www.artigue.com/fiat.php
Ron
Ron Luxmore
rlux2n2@gmail.com
pope
Re: Temp. Guage
Post by pope »
Are you talking about the radiator fan or the heater fan under the dash.
I am assuming the radiator fan. There are two black wires that run from the thermo switch on the radiator. One comes from the fan and the other goes to a ground on the side of the engine compartment. Clean off the contacts on the thermo switch.
After 10 minutes, was the bottom radiator hose hot or cold. That is important. If hot, it could be a ground wire issue, or a bad thermo sensor. If cold, its because there is still air in the engine cooling system or the thermostat, where three cooling hoses connect together is bad or gummed up and not opening.
Also make sure that the bottle cap the black wire is grounded to on the engine compartment side is grounded well to the fender also
fiatfanatic
Re: Temp. Gauge
Post by fiatfanatic »
The radiator fan.
pope
Re: Temp. Guage
Post by pope »
check above post
fiatfanatic
Re: Temp. Guage
Well I got the new gauge in and that took care of it! Thanks again to everyone who responded to this post!!
