Wow, 40 lbs. That's a 50% increase in weight.
I had no idea, never thought to weigh them. What do you think accounts for increase?
That's unsprung weight too, even worse.
rear ends
Re: rear ends
I would guess that its just built stronger to handle the torque from the 2 liter. It has extra brackets near the ends that the early one dosent.
Re: rear ends
The later rear ends came from the Fiat 131/132 range, which were larger, heavier cars than the 124, so they had to have stronger rear ends.
Re: rear ends
from 131, very diferent to rear end on 132. may look simmilar at first glance, but there are no interchangable parts except wheel bearings.
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
Re: rear ends
the 132 is heavier againdjape1977 wrote:from 131, very diferent to rear end on 132. may look simmilar at first glance, but there are no interchangable parts except wheel bearings.
Cheers David
see my >>You tube channel<<
Re: rear ends
yup. and stronger built. depends on what one actually wants to achieve.
