Breaking in the new iengine
- Your car is a: 1975 Spider
Re: Breaking in the new iengine
bran, all you have to do is remove the drive gear from the aux shaft, below the plug for the block mounted distributor, then you can drive the oil pump directly. i have a old drive gear that i cut off and welded to a 1/4" extension, then i just use a drill. but im sure another solution could be found to drive the pump from that loction
son has 78 spider
son has 78 spider
