Timing belt life
- rjkoop
Re: Timing belt life
Ok. For sure I'm doing it. Any tips on removing the cam sprocket bolts? I got 1 off fine but the other, while I was trying to loosen it with the timing belt on, slipped over the teeth of the belt a few times. How can I hold the cam sprocket while turning the bolt?
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
Silly question... Do the allen key bolts that hold the top cover on the camshaft cover have to be removed as well? Maybe that's why I can't remove the full cover...
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
Argh! Once I took the camshaft cover off I realized that there are 4 bolts INSIDE the camshaft cover. Now that those are removed it was easy to pull off the camshaft cover. Now I just have to find the 1 washer that slipped off the bolt when I took out the inner bolts!rjkoop wrote:Silly question... Do the allen key bolts that hold the top cover on the camshaft cover have to be removed as well? Maybe that's why I can't remove the full cover...
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
