Couple of Questions on Floor Renovation
Razooli
Your car is a: 1982 Fiat Spider 2000
Re: Couple of Questions on Floor Renovation
Post by Razooli »
RRoller123 wrote:Thanks Lynn, I think I will do that. It would be a shame to put it all back together and regret not having enough padding, or to actually have it louder than it was!
Seriously! :P
Picking seats up Monday, will post pics (if they look good).
You know they will!!!! :D
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
4uall
Post by 4uall »
I decided not to go with any additional padding. When using foam padding or jute backing, unwanted moisture can easily be the cause of early deterioration in the floor of the vehicle.
http://www.ezcool.ca/
Less than 1oz per sq. ft.
Excellent fire rating.
No bubbles to pop.
Absorbs NO MOISTURE!
1/4" Closed cell foam.
Reflects temperatures over 900°
99% Aluminum facing.
Reflects 97% infrared heat.
Meets DOT FMVSS 302 standards.
RRoller123
Post by RRoller123 »
4uall:
How does the noise and heat level seem with no secondary padding?
Pete
4uall
Post by 4uall »
Huge difference with the heat (& smell with the shifter boot installed). I find it funny about noise levels in convertibles. Wife said she noticed a difference in sound level. :wink:
RRoller123
So the EZ Cool alone made a big difference? What was under your carpet before?
The noise level is a funny one. The low frequencies ("rumbles") are the ones that come through from below and are very fatiguing.
Pete
RRoller123
What do you guys think of this stuff? (Intended use as a carpet pad, on top of EZ-Cool, below carpet)
http://www.amazon.com/25-Increments-Sou ... pd_cp_MI_0
Pete
4uall
Post by 4uall »
Thin padding (see black piece on drivers side of trans tunnel)
Factory tar/coating
RRoller123
Jay:
So you had basically no padding under the existing carpet, just the factory applied hard stuff? I would expect that yes the EZ-Cool would make a huge difference without a secondary under carpet pad!
Pete
124JOE
Post by 124JOE »
i have a roll of 1/2in pad like jute,i used under my carpet.i had a gas leak inside and the tar blead thru the carpet,so last
year i did it up right,i used a rust inhibitor and painted the rust spots,this year ill do the whole floor with por15
the guy who painted my car said you dont want a moisture bearior
and dont seal up the drain holes
i also try to keep it out of the rain,as the tops leak even when new
RRoller123
Why would he say you don't want a moisture barrier? That is the whole idea.
124JOE
Post by 124JOE »
so it can dry out after getting wet
with a barrior it traps moisture and causes rust
unless its adhered directly to the floor"like the tar we start with
RRoller123
If you have a barrier directly on the floor and you put jute or open cell foam or something similar under the carpet and you get a flood, it isn't going to dry out in any reasonable amount of time. The jute just holds it like a sponge. The carpet becomes a barrier to evaporation.
RRoller123
EZ-Cool went in today: "Easy" is correct, but quite tedious. Took the whole day to do it right. I used the Loctite 300 spray, which is excellent! I ran out (you will need 2 cans), went back to the store, they were out of the 300 so I got the 200 (medium duty), and it was terrible, made way too much mist, didn't hold nearly as well. The 300 has good initial grab and holds like nuclear war. The 300 sprays like a fibreglass chopper gun, excellent.
Front seats were ready and I picked them up this morning. The workmanship is fantastic. Mark's Auto Upholstery of Foxboro did them. Dimitri over there is THE MAN. (508) 543-3407, 230 Main Street, Foxboro, MA 02035
Now just waiting for carpets and inner boot seal and wil get this thing finished and ready to drive again.
4uall
Post by 4uall »
AWESOME :!: :mrgreen:
RRoller123
Thanks! Oh and I still have to patch and paint the center console... Wishful thinking that I was near the end on this. Anyone have a recommendation on what to use that is both sandable and flexible to patch goughes, tears, holes etc. in the vinyl center console? Seems like bondo might be prone to cracking, but finding a material that is both flexible and sandable seems at at odds.
Pete
