Page 2 of 3
Re: Painted the Doors and the Jams today.
Posted: Fri Feb 01, 2013 7:36 pm
by rodman
124JOE wrote:dont forget to remove the ground wire and clean up both ends
yeah I will do that
Posted: Fri Feb 01, 2013 10:17 pm
by SLOSpider
Looking good. I did read on some post and maybe you already done it. They say when you paint you should ground your panels and body to get less dust. I don't know how this will effect painting out side but a copper rod run into the ground and to chassis couldn't hurt.
Posted: Fri Feb 01, 2013 10:18 pm
by rodman
SLOSpider wrote:Looking good. I did read on some post and maybe you already done it. They say when you paint you should ground your panels and body to get less dust. I don't know how this will effect painting out side but a copper rod run into the ground and to chassis couldn't hurt.
yeah i will may paint the outside tomorrow IDK yet
Posted: Sat Feb 02, 2013 4:55 pm
by rodman
As most of you are aware our radiators are brass i plan to remove all the paint from the top if mine and polish the brass top.
Posted: Sat Feb 02, 2013 5:15 pm
by dom
I dont see how that will help.
Pick a very calm day, maybe sunrise, and wet the area around the car. Air blow all crevices and holes on the body. You can get a nice finish with little dust under the right conditions. Insects are attracted to the solvents and will trap themselves and make a mess trying to escape.
Posted: Sat Feb 02, 2013 6:48 pm
by rodman
dom wrote:SLOSpider wrote:Looking good. I did read on some post and maybe you already done it. They say when you paint you should ground your panels and body to get less dust. I don't know how this will effect painting out side but a copper rod run into the ground and to chassis couldn't hurt.
I plan lay 2mil plastic on the ground pull the car on top of it. I have 4 poles i am going to put on each corner of the car and wrap plastic 2mil all way around the car it be cheap paint booth...
Posted: Sun Feb 03, 2013 12:19 am
by azruss
I've painted several cars in plastic paint booths. I use 2x4 vertical corners, stake them and tie together with nylon rope. take clear plastic sheeting and wrap around rope and secure with clothes pins. take a piece of plywood and mount a home a/c style squirrel cage fan or a big blade fan. cut a hole in the plywood to air to get into the booth and mount the fan outside the booth with air blowing in. secure the plastic to the plywood with a staple gun. go to a paint supply house and get a good booth filter and staple it to the plywood. leave an entry to the booth in the back corner opposite the fan. the fan will inflate the booth giving it a positive pressure so dust cant come in. I wouldnt recommend plastic on the floor because of static. better to just wet it down. sometimes it is worthwhile to put a baffle in front of the fan to keep a direct blast from hitting the car. I will post pix of my panel booth.
Posted: Sun Feb 03, 2013 12:38 am
by azruss
Here are pix of my panel booth. This is smaller and more stout than my full car booths. I included my door jam pix so you can see the level of quality you can get with nice clean air going thru the booth.
Posted: Sun Feb 10, 2013 6:34 pm
by rodman
Thanks Raze Rims
Untitled by
fiatcs2000, on Flickr
Posted: Mon Feb 11, 2013 1:36 pm
by Hudini
how are you make air out of booth? I see that fresh air is going thru filter in booth.
Posted: Mon Feb 11, 2013 2:42 pm
by azruss
The top picture shows a rock on the plastic. this is a vertical opening where i can get in and out of the booth. the rock just keeps it from blowing wide open.
Posted: Mon Feb 11, 2013 4:49 pm
by Raze
Awesome! I'm very glad to see them on there, and keep going with the resto, looks great! Let me know how much those other wheels weigh when you get a chance and I'll paypal you or whatever.
Posted: Mon Feb 11, 2013 7:16 pm
by rodman
Raze wrote:Awesome! I'm very glad to see them on there, and keep going with the resto, looks great! Let me know how much those other wheels weigh when you get a chance and I'll paypal you or whatever.
Yeah I cant do it till Friday I am on Kid duty this week. I will get them weighed.
Posted: Mon Feb 11, 2013 9:28 pm
by Raze
No hurry, I'm out of town this weekend so do it when you can and let me know.
Posted: Tue Feb 12, 2013 2:12 am
by kev
[quote="rodman"]As most of you are aware our radiators are brass i plan to remove all the paint from the top if mine and polish the brass top.
I would love to see what this looks like when you are done!
