My Affair with Celeste
fiat218
Re: My Affair with Celeste
Post by fiat218 »
i bought mine just as u seen it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
FiatBen
Post by FiatBen »
fiat218 wrote:i bought mine just as u seen it
That's just disgusting!! I've haven't had one that sharp since I bought a new one back in '78.
fiat218
Post by fiat218 »
i agree lol DISGUSTING :D
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
westy64
Post by westy64 »
FiatBen wrote: it has a rollbar.
Do you want to remove it ?
Ready to ship it overseas ?
If it is the case, I'm interested.
Let me know if I can help...
fiat218
Post by fiat218 »
cost u more to ship that then what it worth , don't u think. hell if u wanna pay alot:) i have one
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
westy64
Post by westy64 »
any info about it ?
origin ?
you got it in a car you bought ?
which year (model) ?
any idea of the maker (autopower, other ?)
can you make a few pics ?
I PM you my mail adress.
any price ?
FiatBen
Post by FiatBen »
westy64 wrote:
any info about it ?
origin ?
any price ?
It was in the car when I bought it 8 years ago. The '69s did not have a roll-bar option so it was installed later, but I have no info regarding that. I would agree with Jim that it would be cheaper to have someone make one rather than ship such a heavy bulky item. I like the idea of having the rollbar, so I'll keep it in the car. It has been wrapped in closed cell insulation so I have no idea if it was manufactured or hand-crafted until I unwrap it. At that time I will be sure to take lots of pics and post them so others can see how this one was done.
fiat218
Post by fiat218 »
FiatBen wrote:
westy64 wrote:
any info about it ?
origin ?
any price ?
I'd like to know where it bolted too or welded
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
FiatBen
Rollbar
Post by FiatBen »
Had a few minutes so I went out to investigate.
Wrestled the bottom of the back seat out. Practically had to bend it in half to clear the rollbar. Discovered that this rollbar is not going anywhere. It is welded in at all four mounting points. Well, that should really make the unibody ridgid and maybe improve the handling a little bit?
It is upholstered, not wrapped in insulation like I thought. It makes thick padding and had to be worked at the points where the top linkage comes by in order to fit without ripping the carpeting, which was then wrapped in duct tape, ugly but functional. This will be reworked somehow.
So, I'm guessing the rollbar may have been custom-made. It definitely is not a bolt-in type. It did retain the rear seat, which I think is a bonus. And it's going to stay right where it is. One more reason to think renovation rather than restoration.
Been working on getting organized and moving all the cars into one location, racking 'em up, pulling the tires and getting some weather protection. Here's the fleet today, not counting Celeste (subject of this thread) who is in the garage.
FiatBen
Parts are IN
Post by FiatBen »
Got my box today, now I have the parts to rebuild the ignition, replace the timing belt & tensioner and replace the old water pump. Then we get to see if it will start!!! Aint they shiney????!!!!
FiatBen
Fan, Tensioner & Dizzy questions
Post by FiatBen »
I'm really wanting to make some progress but I need some info.
Cooling Fan - Water Pump:
I'm replacing the water pump, which necessitates removing the fan. It is held by one BIG nut. Anyone know what size this thing is?
Tensioner Bearing:
I am replacing the bearing, even though the old one is still tight (better safe than sorry, right?). I see how this all fits together, but how do I take it apart and put it back together? That spring looks pretty stiff. Also, do I have to pull the bearing and press the new one on?
Dizzy (the car, not me):
I am replacing the cap, rotor, points, condensor, coil, wires, plugs. I don't see an obvious way to pull the centrifugal advance with the dizzy in place so I'm thinking I'll pull it out and check out everything and rebuild it on the bench before putting it back in. I am a bit concerned about not getting it in right, but I've done this once before (many, many years ago). Or, is there a way to pull the advance in situ and replace the points?
These are the things that have me on hold this morning. I really wanted to see if this thing would run by this evening. Maybe not. Oh well, meantime I can continue dismantling the '82 before the unibody goes to the crusher (far too rusted to save).
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Post by dmwhiteoak »
Back off on the nut closest to the tensioner bearing. You should be able to to move the assembly.Pry it and tighten it back down to hold it over so new belt can be installed. I changed mine a couple weeks ago and did not have any problem with removing or installing bearing. Was not pressed on. Maybe stuck a little but not pressed. After installing new belt, use loosen off nut and make sure belt pulls tight. Tighten nut. Nothin to it.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
FiatBen
Post by FiatBen »
dmwhiteoak wrote:Back off on the nut closest to the tensioner bearing. You should be able to to move the assembly.Pry it and tighten it back down to hold it over so new belt can be installed. I changed mine a couple weeks ago and did not have any problem with removing or installing bearing. Was not pressed on. Maybe stuck a little but not pressed. After installing new belt, use loosen off nut and make sure belt pulls tight. Tighten nut. Nothin to it.
Actually, my question is how to replace the tensioner bearing while changing out timing belts. I was able to loosen, move and tighten the assembly to get the old belt off. My concern is how to change out the bearings, hopefully in an easy way.
dmwhiteoak
I had no trouble removing mine. May need a little persuading. If you had a gear puller you might could make it work. Carefull not to damage the stud.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
FiatBen
Horny & Dizzy Celeste
Post by FiatBen »
Been cleaning and tinkering. Here's the latest two things of interest:
Horn - the horn mount appears to have been three layers of angled mount, or one that has delaminated and it is twisting apart.
Pulled the distributor to look it over and noticed this thin plastic cover (or whatever) has turned brittle (in only 42 years) and broken up. As best I can figure all those little pieces had to drop through the gear ring below and into the oil pan.
So what do I do about either of these little problems? Obviously the dizzy problem is much more important that remounting the horn. I don't even know if you can get this little plastic piece. Time to go check the vendors.
