124 Spider Brake Upgrades
I use Tarox G88 discs front and rear. Ferodo DS2500 FCP29 front pads, and Mintex MDB1008 1155 compound rear pads.
I use that on my BC1 racer nad my street BS1. Don't have to change rims or calipers, they are standard size. Pretty expensive stuff, but lasts long.
This brake stuff combination allows me to outbrake many serious racecars in 2.1Km circuit 15 lap FIA Historic Race Championship races with my 155HP BC1.
Sorry Rey,
I should have clarified, my own system uses 11" discs hence the need for 15" wheels.
Tarox 4 or six piston calipers are not going to work with 13" wheels. But as Vassilis points out, they do make OEM size discs for the 124 Spider - 227mm, in G88 or Sport Japan (drilled and slotted) spec to use with your standard calipers.
yes, i understood your system used larger discs. you explained that very well. i dont hesitate going a little overboard on the mods 4 my car, but i really like the nos campanola,s i put on it. they r 13 iches. ive seen the same wheels in 14, but that still wont work with the tarox calipers in your set up. this set up just might do the trick for me and help keep my car looking some what old skool, cept for thet bulge in the hood to clean the carbs. planning on grafting the bump off a mitsu eclipse onto my flat 70 hood. i think it should look pretty cool.
Thanks Vassili
I was wondering what set are you running on the street car ? you post
3 types of pads i am geussing the Tarox for the race car ? and the other
ones on your driver or maybe you change pads for the track type .
It's time to do my brakes and I am going to upgrade them as well ,
Braided lines , Dot 4 brake Fluid or maybe the Silicon base fluid so
i don't have to worrie about moister build up in the lines , I bought
cross drilled rotors now i need pads to complete the up grade .
Dan
Dan
Dan,
Silicone based fluid is compressible. Ok if you don't mind a spongy pedal. But it defeats the purpose of those steel lines. I would suggest sacrificing the hygroscopic resistance of the silicone stuff for a good DOT 3 with high and stable wet and dry boiling points. You could go DOT 4 but their boiling points are not as stable so it requires changing more often.
The other thing I would do to minimize compliance is to make sure you have no flex in any of your mountings.
You got the crossed drilled rotors for weight savings did you? Won't help you stop better unfortunately. Major myth.
J.
J.
Hmmm....I'm not the best to answer this with my limited race knowledge, however...
I've recently seen a study which said that not only do they not help you stop better, but they actually don't help it run cooler either. Apparently the reduced surface area caused by the holes allows it to dissipate the heat less. This means they heat up more. They are however, lighter of course which reduces unsprung weight.
