spring problem
fiat218
Re: spring problem
Post by fiat218 »
dmwhiteoak wrote:Yes Jim. That is exactly what he is saying. Car needs to be sitting on all fours and then torqued to spec. I'm thinking this will solve your problem.
thanks every one, i read that in a book that i had bought on ebay last nite
it shows how u have it back on flat surface then u have theses spacers( call it what ever ) to measure the hiehgt of the car , u set 2 on each side and then u tight en all the bolts.
does any one use theses so call spacer/ pegs or what ever u call them
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Re: spring problem
Post by fiat218 »
do you fiat owners do this when u get your suspension all worked over and new, with new shocks,trailing arms ?
just asking if this part is necessary , or is is just how a person opinion on how it sits ?
i do realize that this set up is for the years up to a 77. i believe. but just asking if this part is necessary. or as some one said , put it back on the ground with the weight of it self then tork your bolts
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
