Clicking sound from under passenger side dashboard
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Re: Clicking sound from under passenger side dashboard
Post by giuliot60 »
salieri124 wrote:Did you guys figure out what was causing the clicking sound?
Yes. Are you getting the same sound?
The PO installed an aftermarket wiper motor and ran a separate line to power it, so the clicking sound was from the wiper relay that didn't have a motor connected to it. When the wipers were turned on, the relay would click. So I just keep it off. :)
I've since purchased a used factory wiper motor, but have not installed it yet.
The other issue I had (car not starting) was because of a loose connection on an aftermarket amp meter gauge. I tightened the connection (I should just replace or remove it) and haven't had another start problem since.
Giulio/Charlotte
Kingme2
Your car is a: 1980 124 Spider
Post by Kingme2 »
giuliot60 wrote:Hi all.
I've recently purchased my 81 and was running the engine for the first time today. I noticed a clicking sound coming from under the passenger side dashboard area. It clicks about every second. I first thought it was the hazard lights or directionals, but they were both off.
Is it from my ECU? Any ideas?
Thanks!
Could be a forgotten passenger, lost inside. Do a "tap tap", listed for a response.
Due to recent budget cuts and the rising cost of electricity, gas, and oil, we have decided to turn off the light at the end of the tunnel. We apologize for any inconvenience.
1981 Fiat Spider, all black... "Corvino", italian for the Raven
salieri124
Post by salieri124 »
Hey Giulio,
Yes, the same sound and stops when wipers are off. I'll check to see if I have separate power line.
