I checked the level after I noticed it stoped leaking and it was right where it should be. go figure At least I got it running and tuned for my wedding this weekend. With that sprint air cleaner it sounds great. I'll post some pix of the latest mods and maybe a few of us in our finery.
matt
Rear Pinion Seal
- manoa matt
Matt, I guess you and your bride are coming to the "mainland" for your honeymoon? My wife and I went to Hawaii for our honeymoon from Alabama (long flight). She wants to move there now. It is a beautiful place. Hey, congrats. Hope ya'll have a great life together!
Anyway, back to Fiat talk; bet it's a pain to find parts there.
Re: Rear Pinion Seal
AS mark has said, you need the crush sleeve to maintain pressure inside the diff. It sort of works like a spring if that helps some understand it. You cannot READ a torque to undo a nut & apply the same to do it up. A nut torqued down to say 100 ft/Lbs may take 150 to crack it off, simply due to friction. It is for this reason that you always torque a nut or stud in one continuious pull of the wrench.
If buying a torque wrench, go for the dearer ones that you preset, rather than the pointer ones. They either click or a pin pops at the desired torque. It's difficult to read a dial AND pull up 100 plus foot pounds. Most good wrenches will come with imperial to Metric conversion charts to show foot pound to newton metres to kilogram metres etc
Re:
I have removed the nut many times since I change the rear end final drive very often and use an impact wrench to remove and install the nut and still no leak's from that area.So Cal Mark wrote:yes, seals usually stop leaking when the level gets too low. Rarely do they fix themselves
