Fuel Vent Hose in Trunk
Re: Fuel Vent Hose in Trunk
Tough to tell without a scale, but it looks about right. If it's an inch or so in length, that's it.
I just realized that my 1981 differs from this to a degree. Trying to figure out which of my tank hoses goes to my pump etc...
- 124JOE
the one that goes to the pump will bubble when theres gas and you blow thru it.joejimmycakes401 wrote:I just realized that my 1981 differs from this to a degree. Trying to figure out which of my tank hoses goes to my pump etc...
Fiat88, a little dish soap on the metal where the filler tube slides over should help ease the install. At least that is what I found when replacing fuel hoses that were a tight fit.
I'm using 8mm fuel hose for my vent. That's fine right.
Woot! Can't wait to get my fuel lines all done. Need a fuel pump bracket and I'm good to go!
silly question, I am able to simply remove those three vapour lines that go into the fuel vapour union without issue? I am looking to replace these.
Fuel vapor union by itzebtze, on Flickr
What's your question? Easily remove them? Mine were easy to take off and on. I had to order new ones. I think I got them from autoricambi??
sorry I am heavily medicated and my grammar is messed up. I wanted to know if I can simply remove these lines (any harm in just taking them off) or is there a special procedure?
I had to use a pair of tin snips to break the original hose clamps.
Mine were factory and I had to use a razor blade to split them and then yank them off.
I will try to clarify.....I have no issue with removing these lines. I want to make sure that I can simply remove then replace them without having to do anything else. Will this create any issues with the gas/vapour lines?
If your battery is in the trunk I would disconnect the negative cable before replacing the vent lines. Gas vapors and spark don't mix well.
Other than that there should be no issues simply replacing each hose with a similar length 8mm hose. You can use 5/16" if you can't find 8mm.
thank you Will get some hose this week.
