centering front license plate
- Your car is a: 1969 124 Spider Convertible
Re: centering front license plate
My '69 came with two bolts in the center of the bumper for license plate attachment.
I bought a small piece of 1/8" aluminium flat bar from the hardware store.
A little cutting, a little fileing a few holes a couple of self tapping screws and WA-LA, front licence plate mount.
Angled it a few degree's to help direct the air flow into the grill.
Can't really even see the mount, beats wire ties
- 124JOE
geno58 wrote:I bought a small piece of 1/8" aluminium flat bar from the hardware store.
ok so where did you put those screws?
got any pics?
I drilled two holes in the lower bumper tube, and used self tapping S.S. screws to mount the Alum. plate.
The plate size is 4" x 8" and I cut mine in kind of a triangular shape. Two holes on the top to fit the Licese plate and two holes on the bottom about 4" apart to mount to the lower tube.
Like thatgrittracing wrote:loose the bumpers and mount it on the lower grill
http://www.flickr.com/photos/21443020@N06/4512902250/
I bought one of those clamps, mounted a steel backing plate holder to it. Done!
What is the PepBoy part #? I've tried searching their website for it w/o luck.
yes like that. But might i sugest using mine or mark's turn signals they are round and they help the lines of the car flow better
- 124JOE
SHAZZAMTobi wrote:Like thatgrittracing wrote:loose the bumpers and mount it on the lower grill![]()
- opus10583
- Your car is a: 1978 CS1
Hi,WYSpider wrote:What is the PepBoy part #? I've tried searching their website for it w/o luck.
PM me, please.
Thanks,
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- opus10583
Due to last nights thunderstorms pictures last night became pictures tonight:
P1050549 by opus10583, on Flickr
A first approximation, I'm not finished, I mounted the KC brackets on the lower tube, upside down, "tabs up":
P1050548 by opus10583, on Flickr
P1050547 by opus10583, on Flickr
Ciao,
Mark
Ciao,
Mark
- 124JOE
i like it. nice car
you can clean up that rust with some steelwool
you local bodyshop supply should have some CLEAR spray inhibater/it turns rust to a sealed surface.
enjoy your ride.joe
enjoy your ride.joe
- opus10583
Hi Joe,124JOE wrote:i like it. nice car
enjoy your ride.joe
Thanks, and again for the tip. I only got it back from "rehab" Saturday, I did pick-up steel wool tonight, and did not know about clear rust converter.
Thanks,
Mark
- 124JOE
after you clean it up it will be less noticeable and any rust turns black but its small.
any time .joe
any time .joe
