Page 10 of 12
Re: 1981 Restoration
Posted: Mon Aug 06, 2012 9:36 pm
by Divers
Posted: Wed Aug 08, 2012 11:42 am
by Weelan
Nice project!
Subscribed
Posted: Wed Aug 08, 2012 1:42 pm
by RCSquadraCorse
Absolutely wonderful engine restoration! My hat's off to you Sir!
Riccardo
Posted: Wed Aug 08, 2012 2:08 pm
by Divers
Thanks! But the real test is will it start and run
I will find out in a month or so......
Posted: Sun Aug 12, 2012 3:01 pm
by Divers
So....head is complete with Marks 274fi cams. Block is all back together......aux shaft lobe is off!
Question...I have Millers adjustable cam wheels with no marking. Before I slap the two together, how should everything be adjusted? Anything else?
Robert
Posted: Tue Aug 14, 2012 12:13 pm
by 124JOE
from you pics i see the motor was not at TDC
it should have been set to TDC before you put on the head
when putting the head on you want them set to #1 intake about to open and exh just closed
as for the aux,put on the original pully,set it,then change and mark it
Posted: Tue Aug 14, 2012 1:04 pm
by Divers
Joe - I had just placed the head on for looks
#4 is at TDC now. Thanks for the info on the cam. Also, my AUX has no lobe so I don't think I need to worry about its location.
Robert
Posted: Tue Aug 14, 2012 7:48 pm
by 124JOE
ok but the aux has to line up with the oil pasages
if it had a lobe it would be for a mecanical fuel pump
it needs to be at the 1oclock so it can oil the head and block
Posted: Tue Aug 14, 2012 7:56 pm
by Divers
Great....I just put the friggin timing belt on......another step back!
Posted: Fri Aug 24, 2012 2:05 pm
by Divers
Posted: Fri Aug 24, 2012 7:50 pm
by 124JOE
looking real nice there drivers
Posted: Fri Aug 24, 2012 9:38 pm
by BEEK
124JOE wrote:ok but the aux has to line up with the oil pasages
sorry this is bad information, there is no timing for the aux shaft except for the fuel pump lobe to miss the crankshaft/rod
there are no oil passages that require timing!
Posted: Fri Aug 24, 2012 9:40 pm
by BEEK
by the way, great looking work. looks as things are coming together nicely for you
Posted: Sun Aug 26, 2012 12:04 am
by 124JOE
so then you olny need to set the aux shaft if you using a mecanical pump?
Posted: Sun Aug 26, 2012 12:55 am
by narfire
124JOE wrote:so then you olny need to set the aux shaft if you using a mecanical pump?
Yeup. If you have wacked the lobe off and plugged the oil galley, no need to worry about contacting #2 rod. Set the aux where ever you like then.
