1981 Restoration
Weelan
Re: 1981 Restoration
Post by Weelan »
Nice project!
Subscribed
RCSquadraCorse
Post by RCSquadraCorse »
Absolutely wonderful engine restoration! My hat's off to you Sir!
Riccardo
Divers
Post by Divers »
Thanks! But the real test is will it start and run :) I will find out in a month or so......
Divers
Post by Divers »
So....head is complete with Marks 274fi cams. Block is all back together......aux shaft lobe is off!
Question...I have Millers adjustable cam wheels with no marking. Before I slap the two together, how should everything be adjusted? Anything else?
Robert
124JOE
Post by 124JOE »
from you pics i see the motor was not at TDC
it should have been set to TDC before you put on the head
when putting the head on you want them set to #1 intake about to open and exh just closed
as for the aux,put on the original pully,set it,then change and mark it
Divers
Post by Divers »
Joe - I had just placed the head on for looks :) #4 is at TDC now. Thanks for the info on the cam. Also, my AUX has no lobe so I don't think I need to worry about its location.
Robert
124JOE
Post by 124JOE »
ok but the aux has to line up with the oil pasages
if it had a lobe it would be for a mecanical fuel pump
it needs to be at the 1oclock so it can oil the head and block
Divers
Post by Divers »
Great....I just put the friggin timing belt on......another step back!
Divers
Post by Divers »
124JOE
Post by 124JOE »
looking real nice there drivers
BEEK
Your car is a: 1975 Spider
Post by BEEK »
124JOE wrote:ok but the aux has to line up with the oil pasages
sorry this is bad information, there is no timing for the aux shaft except for the fuel pump lobe to miss the crankshaft/rod
there are no oil passages that require timing!
75 spider
son has 78 spider
BEEK
Post by BEEK »
by the way, great looking work. looks as things are coming together nicely for you
75 spider
son has 78 spider
124JOE
Post by 124JOE »
so then you olny need to set the aux shaft if you using a mecanical pump?
narfire
Post by narfire »
124JOE wrote:so then you olny need to set the aux shaft if you using a mecanical pump?
Yeup. If you have wacked the lobe off and plugged the oil galley, no need to worry about contacting #2 rod. Set the aux where ever you like then.
