1981 Restoration
kmac33
Your car is a: 1974 Spider
Re: 1981 Restoration
Post by kmac33 »
You fill the idler with the same fluid as the steering box. Should be no issue with removing the brake booster with the master cylinder still attached.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
Divers
Post by Divers »
Thanks Kevin.
124JOE
Post by 124JOE »
some guys remove the booster while its off
Divers
Post by Divers »
Removed idler cap and found heavy grease? what should i do?
124JOE
Post by 124JOE »
clean it out with decil real good
and put in gear oil
or replace the heavy grease
mine fryed up with the header
before i wraped it
but i had a spare
Divers
Post by Divers »
Cleaned out best I could and then filled with 90 weight.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
the idler was originaly filled with a fish oil, as the viscosity does not change with temperature, once you open it up it will be aparent. i do not recomend 90wt, way to heavy, if you must use a mineral oil, i would use a hydrolic oil, the steering will be very heavy with 90wt... over the years i rebuilt 100's of these and replacing the lower seal and 30wt hydrolic oil worked very well
75 spider
son has 78 spider
Divers
Post by Divers »
Finally got my new dash installed, new gauges wired and new 15" steering wheel.
http://i839.photobucket.com/albums/zz31 ... orfiat.jpg
jimmycakes401
Post by jimmycakes401 »
Woah. Cool. I'm jealous.
jimmycakes401
Divers, do you have a public album? I can't find it on photobucket.
Divers
Post by Divers »
All of my albums are private.
Robert
If I can help with a particular picture, just ask.
Divers
Post by Divers »
Well.....after a 2 month wait....the engine house begins work on my stuff!
Working out plans for an exhaust system currently and going through all the wiring. Slow going.....but progress.
fiat124fl
Post by fiat124fl »
When it's going to be ready for paint?
Divers wrote:Well.....after a 2 month wait....the engine house begins work on my stuff!
Divers
Post by Divers »
Next year when I have more funds to do a nice job.
Divers
Post by Divers »
Finallygot my block back from the machine shop with new pistons installed....now maybe I can get this project moving again. Anyone know how to put an engine together :)
